I have a Dell Optiplex GX280 which i was given that just needed a hard disk.
I have bought a new hard disk and just loaded win xp onto it using a different computer.
The trouble is now I have put the disk into the dell pc it won't boot up. I get nothing on the screen at all, the light in the power button is
orange instead of green and the monitor doesn't turn on either. Any ideas?
Would not having a key board and mouse connected effect this? I have keyboard and mouse but can't connect them as they are PS/2 (round)
connection and the PC is USB only. I would of thought I would still get something on screen.
Any help appreciated.
Stu.
[Edited on 17/8/08 by stuart_g]
I may be wrong, but you cannot put a hard disk with a windows operating system from one pc to another. I think its to stop you using your copy of
windows in more than one machine. When you install windows it inspects the hardware of the machine so can tell when you put the disc into a new
tower.
Have you tried booting from the XP disc and installing windows on the new machine? The only problem with that is that you will need to purchase a new
serial key unless you have a hooky copy
I have tried booting the computer up with the xp disc in and it does the same thing. This is why I thought I'd try a hard disc with xp already on it.
Is this the machine with the DVI socket you were asking about.
When you power it do you see the bios screen.
If you were given it does it have ram or does it beep when you fire it up.
Bob
Sounds like it needed more than a hard drive! Do fans etc start when you turn it on?
Liam
Yes it is the machine. I have the adapter cable now.
No I do not see the bios screen monitor does not turn on and yes it has ram in it.
I have tried plugging the monitor into the socket on the mother board aswell (with and without the graphics card installed).
Processor fan runs when turned on.
So it doesnt have a standard graphics socket on the chassis above the DVI one (obvious question I know otherwise you wouldnt have asked about the DVI
socket)
Sounds like the graphics card is tatered.
Bob
Is it the original memory? A mis-match on the supported memory would cause the same symptons.
Yes it is the same memory.
I think on a Dell he would still see the start of the Dell bios screen then get beeping with ram probs Joneh, he'd get beeping for sure unless
someones taken the sounder off the M/ board.
Bob
Stu - On the rear of the Dell GX there's a row of four diagnostic LED's. Could you tell me what the four are displaying please when you
plug it in and power it on?
Is the power button LED orange as soon as you apply power or after you press the button?
Originally posted by splitrivet
I think on a Dell he would still see the start of the Dell bios screen then get beeping with ram probs Joneh, he'd get beeping for sure unless someones taken the sounder off the M/ board.
Bob
Bob
Depends on BIOS.
Could also be a duff CPU.
Have you tried re-seating all the components?
Edit: Tried resetting the CMOS? Take the battery out and move the jumper over for a few seconds.
[Edited on 17/8/08 by joneh]
Originally posted by McLannahan
Stu - On the rear of the Dell GX there's a row of four diagnostic LED's. Could you tell me what the four are displaying please when you plug it in and power it on?
Stu - Disconnect all the CD ROM internally (should be IDE) and the power to it too. Do the same for the recently added HDD (SATA you said?)
Could you also disconnect the power connection to the board. Re-seat it really firmly and try powering on again without the HDD and CD/DVD
attached?
A solid orange power LED is often a power supply failure - Doesn't power the board up on every circuit. Flashing Orange is it's stuck in
sleep.
It could be board too. Next to the CPU towards the rear there's a row of capacitors - most disappear under the CPU fan/exhaust. Are these
capacitors domed at all or leaking?
PC isn't reaching BIOS if none of the LED's come on or even flash. It's not a good sign I'm afraid.
Each Optiplex (with an Intel interestingly) does have a 3 year warranty but the GX280 are coming to the end of that - about 3 months ago in fact.
http:
//support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/my_systems_info/en/details?c=uk&cs=ukdhs1&l=en&s=dhs
Worth a quick check anyway - It may still have warranty left!
Could you also disconnect the power connection to the board. Re-seat it really firmly and try powering on again without the HDD and CD/DVD attached?
A solid orange power LED is often a power supply failure - Doesn't power the board up on every circuit. Flashing Orange is it's stuck in sleep.
It could be board too. Next to the CPU towards the rear there's a row of capacitors - most disappear under the CPU fan/exhaust. Are these capacitors domed at all or leaking?
http: //support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/my_systems_info/en/details?c=uk&cs=ukdhs1&l=en&s=dhs
out of warranty aswell
Originally posted by stuart_g
The PSU I'm sure is ok as I loaned it to a mate who's PSU had broken and it worked his system ok.
Did you check the capacitors behind the CPU Stu? Row of about 8 or so?
Definately my PSU as it is completely different to mates one.
The row of 8 capacitors appear to be ok.
Not looking great then?!
Have you removed any memory and tried booting?
If there's two/four modules installed remove each in term and if there's only one swap it to the other slots?
Dell use a different PSU pinout compared to standard ATX format - was it a Dell PSU you borrowed?
