I'm sure there is a way to convert vist back to XP. any ieas fellas?
Though it was only me who thought Vista is Crap. My understanding is a format is required and a new install Can 2 operating systems be used ??
Yeah, format disk...stick XP cd in and away you go.
not always that easy with sata disks.
google your pc first
According to Microsoft this is not possible and to go back to XP you will need to start from a fresh install.
Dont know if anyone has managed to unofficially to downgrade.
I must have got it wrong then as i thought Vista had an option to downgrade itself!! I'm sure i read it somewhere!
Think you are thinking about when some manuafacturers used to supply a downgrade cd.
Rich
a friend of mine has removed Vista home premium wit the fresh install method and now runs XP says its the best thing hes done laptop 3x faster initialy had a few problems with locating drivers as Laptop was new but since sourced them now he has a beast of a machine
If you have a vista Proffesional(business) liscense you CAN install XP..
If you have vista home.. you cant...
You will need an xp CD...and do a fresh install...you need to wipe, and extra wipe the hard disk to remove the awful vista...
If you have issues getting it to work on a newish laptop with sata disks....just go into BIOS and make sure the hard disks are in compatibility mode
or somesuch...
And if you have a recovery partition on your machine with vista in it...nuke that to hell as well before you isntall XP
I really dont know what peeps problems are with Vista, I have been using it for awhile now on a cheap spec Dell laptop and its fine!
Much better than XP thats for sure, Its so much easier connecting to networks and things like that. XP looks clunky by comparison too.
I do admit it has it problems, the most annoying of which is that you have to disable UAC to unistall programs otherwise it says you do have
permission, even if your on the admin account.
but honestly i wouldn't go back.
Also the other annoying thing is that quite a few programs don't work with Vista, the copy of goldmine we have doesn't. This is to be
expected tho.
Just gone from Vista to XP on my new pc, just check all the drivers for your hardware are available for XP, as some of the bus drivers for my pc were
only written fo vista!
Ray
Trogdor ftw ^
I rebuilt my pc last week after I had used Vista for a year. I couldn't find my vista disk so I installed XP again. Jeeeeeez what a piece of
crap. It was so buggy. Found my vista disk again though so it's all good. I don't understand vista being slow either, I can go from the boot
up screen into windows (& everything is fully loaded) in about 15 seconds. In a year of using vista it's never once crashed/frozen. It
pwns
XP is like a blind old incontinent sheep dog, he's had his day. Take him out to the barn with a double-barrelled shotgun and blow the mother
away.
[Edited on 23/10/08 by Benzine]
Cheers chaps, i'll pass the info on to me mate!!
Much appreciated.
Vista is usually fine if it has enough memory ie 4gb+ and most of the options turned off.
XP as an operating system is OK these days as long as you have at least 512mb and avoid SP3 and IE7
Best operating system MS ever produced was Windows 2000 with NT4 close behind but running either these days isn't practical because of driver
issues.
IF you want a bullet proof operating system put either Mint Linux or PC Linux OS on.
Originally posted by rayward
Just gone from Vista to XP on my new pc, just check all the drivers for your hardware are available for XP, as some of the bus drivers for my pc were only written fo vista!
Ray
Just installed vista ultimate 64 bit on my pc, but done a dual boot with XP Pro for progs like SW06 which just wont work on Vista.
As of yet I havent had any problems, infact I am quite liking Vista, and even in its infancy it doesnt seen half as buggy as XP after SP3!
My only bug with Vista is my scanner which is incompatible but it is 5 years old and we have a 2000 pro which runs it fine.
I've installed Vista a few times to try and it has got better over time but I did it last week and still ended up going back to XP. I don't
need to upgrade my PC to 4GB RAM under XP so I see no reason to under Vista but constantly tries to cache things to RAM after startup even though I
turn off a lot of indexing services etc.
Which drives me nuts as I have a Raptor boot HDD and they sacrifice fast heads seeks for quiet operation. My other issue is the network transfers
speeds. I can't remember the exact details off hand but basically its slower compared to XP unless you make various OS changes and the network
stack has a low prioity so can easily be affected by other processes. I do quite a bit of network transferring so prefer XP in this case.
As i usually go for a minimal, uncluttered desktop appearence I always turn off the glass interface and other effects so again I might as well stick
with XP.
I do though quite like several features on my HTPC and so will stick it on their instead.
Originally posted by graememk
arghghghgh just remembered why my sites been so busy its stilll on trade from your order lol...woops
my laptop has 1gb of ram, and is only a single core processor, cheap as chips and it runs vista fine, certainly no slower than XP and thats with all the vista pretty stuff running.
Can I go to 64 bit after initially having it 32?
