Wheels advice please
Wheels244 - 15/11/11 at 06:23 PM
Hello All
I've got my eye on a set of wheels
PCD - 4x108
Bore - 65.1
Offset - 19
Will these fit my Locost - DeDion rear end with Sierra diff and shafts and Cortina uprightshubs
Is the offset ok ? Where will it position the wheels ? I want them to fill the arches properly. If not, what offset do I need ?
Thanks for any advice.
big_wasa - 15/11/11 at 07:02 PM
Cortina front end would be et 18 ish, from ford anyway. Sierra would be et 38 so your back wheels will stick out an extra 20mm.
As to if it will fill the arches that will depend on the arches. The fronts will be fine as you can just space the brackets.
Best to try and borrow one and stick it on the back.
The bore I cant remember. Are they ford or aftermarket ?
Wheels244 - 15/11/11 at 07:08 PM
Thanks for the reply.
They're after market - they're too far away for me to try unfortunately.
I'll try to post a picture up of the rear arches - I don't know if you'll be able to tell from that ?
Wheels244 - 15/11/11 at 07:13 PM
big_wasa - 15/11/11 at 07:22 PM
No, it will also depend on the width of the rim.
MkII - 15/11/11 at 07:23 PM
I've got a spare set that size if u want to try them. .m.
