fancon2
fancon1
fancon3
The fan is a Rover Metro I think. Does anyone know the connector type & where to get one from?
First places I'd look would be Vehicle Wiring Products or Premier Looms. Failing that, a scrappy visit with a pair of cutters to retrieve one with some cable attached.
try here
http://www.polevolt.co.uk/acatalog/Unsealed_Connectors.html
Hi
I would just use 2 small spade connectors, or solder a pair of wires on with heat-shrink
job done.
Otherwise if you absolutely want a plug, a trip to the scrap yard as said
good luck
René
2 small spade connectors pushed on and then filled up with sikaflex to seal from the elements, this how I did mine and has been a good as gold and
looks oem if done right.
Rich
Thanks, I think I'll go the sikaflex route. I'll put a bit of vaseline around the inside of the connector so hopefully I'll be able to remove it if necessary. Cheers.
Dataspares offer a good selection of connectors and connections.
Here's their two pin offerings....
http://www.dataspares.com/2way.html
