Author: Subject: XP problem poss virus?
speedyxjs
posted on 22/11/08 at 08:26 PM Reply With Quote
My little sisters laptop has a problem. When you switch it on, it manages to get to the XP loading screen (with the load bar at the bottom), and then restarts and carrys on the loop.
I have tried starting in safe mode but it just does the same.
Any advice much appreciated.
dmac
posted on 22/11/08 at 09:06 PM Reply With Quote
Probably a corrupted file on the boot disk. If you can, boot from a recovery disk and run scandisk or some other disk recovery tool. As a last resort try the windows repair option.
Duncan
speedyxjs
posted on 22/11/08 at 09:11 PM Reply With Quote
Thanks dmac. Dont have a recovery disk. How do i use the windows repair?
posted on 22/11/08 at 09:29 PM Reply With Quote
Could also be a knackered memory stick... Try booting a Memcheck CD-rom and letting that run for a few hours....
dmac
posted on 22/11/08 at 09:30 PM Reply With Quote
To use windows repair, you boot from your windows XP disk and select the repair option.
You can make a repair disk using the information at http://www.ubcd4win.com/
Duncan
meany
posted on 22/11/08 at 09:33 PM Reply With Quote
i agree with the above, it happened to me a few months back, i tried allsorts, all to no avail...then realised my Dell PC has diagnostic lights on the back.....doh..
turned out to be one of the Memory sticks was knackered.
dmac
posted on 22/11/08 at 09:36 PM Reply With Quote
Its worth checking the memory (and the boot CD from the link I mentioned has memory testers built in) but memory problems are usually identified earlier in the boot process.
Duncan
vinny1275
posted on 23/11/08 at 12:10 PM Reply With Quote
There are a couple of other options in the safe mode boot menu - you can get it to tell you which drivers it's loading as it does them - the last one to try before it reboots itself is likely to be the culprit. You then might be able to replace the file with a good copy from another machine.
HTH
vince
