| posted on 14/1/10 at 07:26 PM |
wireless printer?
just purchased wireless printer: epson sx515w
i thought I could connect wirelessly from my dell laptop with no additional hardware ..... but it seems I need to have a wireless network/hub or
whatever it is called - correct?
in other words: lappy talks to hub;
printer talks to hub
and
lappy does not talk directly to printer.
GMPMotorsport
| posted on 14/1/10 at 07:35 PM |
I am no computer whizz but I have a Dell laptop & a Cannon printer that I use via bluetooth and this works fine.
www.gmpdevelopments.co.uk
www.gmpmotorsport.co.uk
ARDS Instructer.
prawnabie
| posted on 14/1/10 at 07:38 PM |
can you not set up an ad hoc network instead of infrastructure? My espon lets me choose so pretty sure yours would.
[Edited on 14/1/10 by prawnabie]
Jubal
| posted on 14/1/10 at 07:39 PM |
Doesn't your internet router do wireless?
James
| posted on 14/1/10 at 07:41 PM |
and
Absoloutely.
You need a wireless hub/router to actually 'route' the network traffic.
For most people this is their broadband router but it doesn't have to be. You can go and buy a wireless hub.
BTW, that printer is a chuffing bargain at that price! (assuming you got the 60-70quid ish price it's at in PCWorld).
James
EDIT: I hadn't read what Prawnabie had said when I typed that. His suggestion may be possible.
[Edited on 14/1/10 by James]
- Muhammad Ali
| posted on 14/1/10 at 07:52 PM |
yeah, the ad hoc seems to be direct from lappy to printer but when I did the set up, it was asking for SSID (I don't have a network so what to
enter?)
locostbuyer83
| posted on 14/1/10 at 07:54 PM |
do you not use a router?
you just need a device to get both devices on the same network and give both devices an IP address.
locostbuyer83
| posted on 14/1/10 at 07:55 PM |
enter?)
The SSID is the wireless network name. if your using a cable you wont need to use that. just give the printer a static IP address and add it to the PC
using that address.
| posted on 14/1/10 at 08:14 PM |
if i am using a cable, then that is not wireless is it???
so i do need some third piece of hardware as i stated in first post; damn
bob
| posted on 14/1/10 at 08:57 PM |
I've got the epson sx515w and yes you need a cable to set up, i thought it strange but if you follow the instructions to the letter all will
become clear.
Regarding SSID as siad put in your wireless network name as used on your router that feeds the laptop.
| posted on 15/1/10 at 07:33 AM |
^^^ yeah, it is simples as you say but I don't have wireless network nor router.
a reply to my post on dell website says that the lappy can be set up to create an ad hoc network .... googling it right now.
locostbuyer83
| posted on 15/1/10 at 08:04 AM |
If you dont have a router or device to link the two then you will need to USE A CROSS OVER NETWORK CABLE and give each device a static IP address.
Give your PC the IP address:
192.168.0.1
255.0.0.0
Give the printer:
192.168.0.2
255.0.0.0
Local Gateway: 192.168.0.1
then add a new local printer printer, use a TCP/IP port and enter the address 192.168.0.2
MikeRJ
| posted on 15/1/10 at 09:31 AM |
SSID isn't important as long as it's the same at both ends, it's simply an identifier for your wireless network.
"02GF74" would be fine
