Ivan
| posted on 13/10/10 at 09:19 AM |
Stupid Excel question
I have an Excel 2007 spreadsheet with 75000 rows of data across 50 columns in it.
I have created a new column and want to fill it with a formula - it is not practical to drag the formula down all 75000 rows (takes forever and causes
my finger to start shaking holding down the mouse button) - is there short-cut way to fill the column with the formula?
kendo
| posted on 13/10/10 at 09:24 AM |
copy the formula you want in the column. Then select the column by clicking the header and then paste.
Job done.
jossey
| posted on 13/10/10 at 09:25 AM |
ye just work out the formula for the first line and copy it (ctrl c)
then highlight the whole column and click paste.
will take a while but will do it all for ye.
dave j
:O)
loggyboy
| posted on 13/10/10 at 09:41 AM |
Copy for cell/forumla,
Select the first empty Cell,
go down to the bottom, hold down shift, select the bottom cell, then paste?
GBaggott
| posted on 13/10/10 at 09:42 AM |
easiest way - hover over the bottom right hand corner of the cell with the formula in, a black cross will appear then double click and it will go all
the way to the end of the data, job done
GBaggott
| posted on 13/10/10 at 09:46 AM |
nb: any breaks or gaps in the data then it stops at the gaps. Cheers Gareth
Ivan
| posted on 13/10/10 at 10:13 AM |
Thanks guys - you are stars
Knew I could rely on you.
