Author: Subject: Slow computer
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 3/1/12 at 08:22 PM Reply With Quote
Slow computer
Just of late my pc seems to be really slow especially on my yahoo email, it occasionally freezes all together and every so often the hard drive starts making a noise like its down loading something. Any techies out there that can help.
flibble
posted on 3/1/12 at 08:27 PM Reply With Quote
If your HD is making 'working' noises it could well be that your low on RAM and it's haveing to use the HD to supplement it, is it and old PC with not much RAM (ie. under 1gb)?
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 3/1/12 at 08:30 PM Reply With Quote
Pc is about 4 years old. Pretty sure it had 4gb of ram but how can i check ?
Disk cleanup is done regularly and defrag checked.
Run adaware every so often too.
[Edited on 3/1/12 by CRAIGR]
flibble
posted on 3/1/12 at 08:36 PM Reply With Quote
Should be ok then but you type "dxdiag" or "dxdiag.exe" (I forget which) into the "run" bar in the program menu and the info will be there.
Try running CCleaner and MalwareAntiBytes(sp?) to see if anything can be cleaned up etc.
While it's running slow you can always press CTRL+ALT+DEL and look in the task manage if anything is using up lots of memory or cpu %.
Just some basics to try before more knowledgable peeps turn up to help
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 3/1/12 at 08:41 PM Reply With Quote
Will have a go.
If i do CTL,ALT,DEL then processes there are loooooooadsssss of things going on.
flibble
posted on 3/1/12 at 08:45 PM Reply With Quote
Any high % numbers in the CPU column?
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 3/1/12 at 08:46 PM Reply With Quote
Going from aboput 9% and spiking to 75+.
Idling between 9 and 45%
flibble
posted on 3/1/12 at 08:51 PM Reply With Quote
If you're not doing 'owt on your PC then nothing should be hitting 75% I'd doubt!
Tell us the offending process names (rundll32.exe etc.), and it may shed some light (or likely not )
ChrisL
posted on 3/1/12 at 08:54 PM Reply With Quote
if your HDD is working more than usual then it's memory you need to look for. When the PC runs out of RAM (memory) it save some of the memory to disk. This is known as paging. I'd use task mgr to identify any process that's using lot's of memory and then try to find out if that's normal usage (web browsers are bad, especially on adobe flash)
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 3/1/12 at 08:57 PM Reply With Quote
AcroRd32.exe
NCRSRVCE.EXE
MOTIVE(funny squiggle)1exe
RapportService.exe
More than 6 iexplore.exe
scureapp.exe
AAWService.exe
and a whole lot more
PF usage whatever that is is running at 3.04gb
Physcal memory
Total 2095532
Available 137804
Sys cache 194448
SeanStone
posted on 3/1/12 at 09:01 PM Reply With Quote
Hard drives are by far the slowest component in a computer but they rarely make that much noise
What operating system are you running?
When did you last re install windows?
Have you cleaned it inside recently?
IF it isn't hard drive then I would use memtest to test your ram for errors as bad ram can make a system crawl
flibble
posted on 3/1/12 at 09:07 PM Reply With Quote
Not sure of some of those processes (exept the dreaded Norton AV (NCRSRVCE.EXE)).
Before you try anything difficult I'd personally download CCleaner (don't forget the registry cleaner bit of the program too) and let do it's thing, followed by MalwareAntiBytes (or similar) scan
mookaloid
posted on 4/1/12 at 12:00 AM Reply With Quote
Originally posted by CRAIGR
AcroRd32.exe
NCRSRVCE.EXE
RapportService.exe
scureapp.exe
AAWService.exe
Physcal memory
Total 2095532
Available 137804
Sys cache 194448
you seem to only have about 5% RAM available and PF usage at 3gb looks very high to me.
Is your task manager showing anything using lots of memory? (you can sort the columns to easily see what is using the most) You could upgrade the memory from the current 2GB to say 3 or 4GB but on its own it wouldn't cure this you still need to be finding out what is hogging the memory.
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 4/1/12 at 08:46 PM Reply With Quote
Thanks for alll the help guys .Seems it only has 2gb of ram 1gb in each of 2 slots. Wheres the best place to get some more 2gb or 4gb desktop pc ones
[Edited on 4/1/12 by CRAIGR]
flibble
posted on 4/1/12 at 09:28 PM Reply With Quote
I buy mine from Dabs.com or overclockers, but as said above, I'd try to pin down what's hoovering up all your available RAM at the moment first
britishtrident
posted on 4/1/12 at 09:51 PM Reply With Quote
You seem to have a lot of unwanted junk or possible malware running in the background time for a clear out and virus scan or fresh install of Windows.
Your running Norton --- which is the equivalent of trying to drive with your foot on the brake.
AAWService.exe should be Lavasoft Adaware a good product however recently a lot of people around the web have been posting having problems with it hoovering up resources.
More than 6 iexplore.exe ---- seems odd not mention of it anywhere on the web which sets off alarm bells and any case IE6 is an obsolete product.
[Edited on 4/1/12 by britishtrident]
[/I]
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 4/1/12 at 09:56 PM Reply With Quote
There are 91 processes running .
One of the iexplore.exe is using 993,435k another is using 118,628k another 91,000k another 98,800
flibble
posted on 4/1/12 at 10:10 PM Reply With Quote
Bloody hell, "993,435k" thats a lot!
As a comparison, I've 3 iexplore running: 24500k, 6009k, 57000k
[Edited on 4-1-12 by flibble]
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 4/1/12 at 10:23 PM Reply With Quote
It was over 1000,000 at one point.
Dare i end it ??
ChrisL
posted on 5/1/12 at 05:15 PM Reply With Quote
End and use firefox or another alternative. IE does tend to get lot's of search bar and add ons installed. If you want to stick with it then try removing some of those. Also noticed you've got the trustier rapport software installed, no doubt your bank suggested it, that could be removed. I'd look at all of my runny processes in mem / cpu priority and remove the ones that you don't need.
Also question any high men / cpu processes, as flibble said, 1GB of memory being used by 1 IE process is a lot, it's half your memory!!
jossey
posted on 5/1/12 at 05:24 PM Reply With Quote
i re format my pc every year or so just to clean it up properly as it does get messy in its old age.
when you get it all set back up just make a norton ghost image of it so you can get back up and running quickly.
then dont save owt on the same drive letter as the windows install.
Have you used CPU-z to check temperatures of ye CPU etc....
maybe dust on your processor cooler etc...
more likely to be just need a format and reinstall.....
David Johnson
