Author: Subject: Saving backing up emails
locoboy
posted on 6/10/04 at 01:55 PM Reply With Quote
Hi there, i currently run outlook express 5 and am upgrading my pc and windows to xp.
i need to know if i can drag and drop all my emails sent and received and the filed ones onto a cd then re-install them when i get the machine up and running again. If so what file type do i save them as and how do i go about doing it n one foul sweep
simonH
posted on 6/10/04 at 02:05 PM Reply With Quote
user settings transfer wizard
put the XP CD in the machine and one of the options is user settings migration wizard. it will produce a folder for you that you can burn to CD then reimport after the update which will contain all you mail , ie favorites software settings etc
locoboy
posted on 6/10/04 at 02:16 PM Reply With Quote
well i am actually getting a new machine not upgrading my old one, the new machine is comming with XP installed already so no cd with it i assume.
Locoboy
Noodle
posted on 6/10/04 at 02:23 PM Reply With Quote
If you've got link cable (serial/ethernet) the XP wizard thingy will copy the info across. It will generate a floppy to run on the old machine to kick off that side of the process.
I recently did it between an old Win98 machine and XP. The problem was that it took 12 hours over an old laplink cable and failed to take all of the email folders. I tried many permutations but finally settled for hanging an IDE cable out the back of the old machine to a CD burner and copying all the outlook express mail files (.dbx I think) and exporting all the account settings (.iaf) and burning them to a CD. Then I put the CD in the new machine and imported the settings (for the mail server) and copied over the old dbf's. Bingo!
Neil.
Your sort make me sick
