Author: Subject: Dialers help please
mookaloid
posted on 7/6/05 at 07:42 PM Reply With Quote
Dialers help please
One for the computer whiz kids...
How can I check to see if my dad's computer has aquired one of those dialer things which connects at a premuim rate?
TIA
Mark
flak monkey
posted on 7/6/05 at 07:45 PM Reply With Quote
Use a program called spybot, available from here:
http://www.safer-networking.org/en/index.html
Download it, update it and run it. it should find anything malicious.
If that fails you can use hijack this:
http://www.spywareinfo.com/~merijn/downloads.html
but it requires a bit more knowledge about what you are doing!
After running that, carry on with a virus scan. And even a scan with Adaware SE:
http://www.lavasoftusa.com/software/adaware/
to make sure you have got everything.
(Just found the links to all the software)
[Edited on 7/6/05 by flak monkey]
Sera
http://www.motosera.com
mookaloid
posted on 7/6/05 at 07:58 PM Reply With Quote
Thanks Mate- I'll give those a try
Mark
flak monkey
posted on 7/6/05 at 08:07 PM Reply With Quote
No worries, I hope one of them solves the problem(s).
Sera
mangogrooveworkshop
posted on 7/6/05 at 08:54 PM Reply With Quote
mark call BT and ask them to bar premium rate numbers
mookaloid
posted on 7/6/05 at 10:22 PM Reply With Quote
Also a very good idea
Mark
britishtrident
posted on 8/6/05 at 08:08 AM Reply With Quote
Hijackthis is the only 100% cure for all dialers
It should be run regularly to monitor changes in the registry.
Make sure you get the real hijackthis from http://www.spywareinfo.com/~merijn/downloads.html
Usuall instruction about disabling "auto system restore" and running in safe mode appy.
Free-AV will stop most dialers from installing.
Mozilla Firefox and Thunderbird should also be used they are much more secure against this kind of threat intalling itself than the MS software.
The ultimare protection from dialers is to go broadband and pull out the modem lead unless your are faxing.
