Dusty
| posted on 22/9/05 at 10:57 AM |
Administrator Password
A friends son has tidied up 'unwanted' files on his computer which is running XP to the extent that it completes its power on boot tests
gives a single peep saying all its hardware is OK but then fails to even start loading windows with a message about 'no NTLDR'
He has a rescue/repair disc but this asks for an administrator password which he can't remember ever setting and if he did set one hasn't
a clue what it was. I can browse his hard drive as slave in my machine after removing about 40 W32.wullik infected files and some dialers (leaving 60
other manual removal bits of malware) where might I find passwords please?
HELP!
Tiger Super Six
| posted on 22/9/05 at 11:14 AM |
If he didn't set one then it may just be blank.
Mark
Tiger Avon
Strolls
| posted on 22/9/05 at 11:29 AM |
If it's not blank then there's a bootable CD I've used in the past that can reset the admin password to blank. It's based on
Linux, but don't worry - it just boots to a menu allowing you to select which installation of Windows you want to access & stuff. I'm
pretty sure this link is to the CD I've used.
But honestly, you're best off using your PC to pull all his data off the old disk & telling him to reformat the drive. His files will be in
C:documents & settings<his name>my documents and email will be in something like C:documents & settings<his name>application
dataMicrosoftidentitiesoutlook express but I just pull everything off & worry about it later.
Stroller.
Hellfire
| posted on 22/9/05 at 12:44 PM |
Press f8 before windows starts, select boot device. Place original XP disc into selected drive and re-install windows if all else fails. It will not
overwrite any documents but slap his hands as a due punishment!
Dusty
| posted on 22/9/05 at 01:38 PM |
Excellent. I'll give it a go. I've already told him its probably caput but there is stuff on there he wants to try and save.
RoadkillUK
| posted on 22/9/05 at 06:18 PM |
Like the Haynes manual's 'Check you have petrol in the car', make sure he doesn't have a non-booting floppy disk inserted.
Really it does happen
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
