flak monkey
posted on 25/10/05 at 08:20 AM |
More internet woes
Our internet is completely down at home at the moment (and has been for around a week now).
If anyone knows how to cure the problem below I would be most grateful.
The fault is the router cant find the PPP server, and hence we cant access any web pages as it wont let us log into our account. The ADSL line is
fine, and all the tests on it work ok.
Rung the ISP and they said there is nothing wrong with our account, and it shows us as connected (which we are not!). And yes the house phone works
fine.
We have reset the router, both hardware and software. Tried pinging IP addresses (all of which fail) etc etc.
It sounds like an ISP problem to me, but they say its all OK.
Sera
http://www.motosera.com
shortie
posted on 25/10/05 at 08:29 AM |
Sorry mate, have to say it does sound like a network problem to me with your network connecting to your router, not the ISP.
Is it wireless or hard wired to your router?
Rich.
flak monkey
posted on 25/10/05 at 08:50 AM |
As is sods law...I post and ask for help and it starts working again!
We are all wired to the router, and we could all see each others computers and access them etc. Just the PPP server couldnt be found...
Odd, but it appears to be fixed now...hopefully!
Sera
shortie
posted on 25/10/05 at 08:52 AM |
Oh well, all's well that ends well, glad it's fixed.
Hellfire
posted on 25/10/05 at 09:21 AM |
I have a similar problem with my wireless home network. Desktop can see the laptop but ICS won't work... I've tried alsorts with little
luck.
Anyone help on this one?
CommanderAce
posted on 25/10/05 at 09:42 AM |
what kind of wireless set up do you have?
Access Point infrastucture, Ad hoc?
Roads? Where we're going we don't need roads!
Hellfire
posted on 25/10/05 at 03:57 PM |
Ad-hoc... on 802.11g
I get file sharing but no ICS... I had a feeling it's firewall as Kerio (free version) does not support ICS. Even with FW disabled it
doesn't ICS
CommanderAce
posted on 25/10/05 at 05:44 PM |
Kerio is quite hardcore with what is accepts/denies so that may be it. What OS are you running on the machines?
Hellfire
posted on 28/10/05 at 03:49 PM |
XP Pro SP1
They're not supporting Kerio anymore or so I was told. Anyone else know a good free firewall?
[Edited on 28-10-05 by Hellfire]
flak monkey
posted on 28/10/05 at 03:52 PM |
Sounds like a stupid question but is your ICS turned on on your wireless router? Can you connect with a cable and check it works, then you know
whether its your wireless network or your ICS.
We all started off on a wireless set up, but it was such a pain and so slow that we are now all on wired connections.
And you have got the TCP/IP enabled in your wireless connection settings right? (Right click network connection in control panel and select
prperties...)
There is also this useful linky:
http://www.homenethelp.com/ics/index.asp
[Edited on 28/10/05 by flak monkey]
Sera
Hellfire
posted on 28/10/05 at 04:05 PM |
Hi flak - I have no router just a wireless adapter and PC Lan card. I had it working with my old laptop but it simply won't Internet Share
I have ICS turned on yes.
I have my TCP settings configured as ports 192.168.0.1 and slave as 192.168.0.2 and I've also tried auto to no avail. I'm not having any
luck whatsoever... personally I was going to go the wired route initially and it looks like I'm going to end up doing that.
Have you tried the telephone socket sharing thing I've vaguely heard about?
flak monkey
posted on 28/10/05 at 04:19 PM |
My TCP/IP settings are:
IP Address 192.168.1.5
Subnet Mask 255.255.255.0
Default Gateway 192.168.1.1
I think usually that over a network the gateway is set as 192.168.1.1, not 192.168.0.1 though I could be wrong.
Your DNS server should be whatever your net company told you, or just leave that on auto.
If you go to start, run, type 'cmd'. Then type 'ipconfig', what do you get?
Also if you type 'ping 192.168.0.1' what do you get?
Miss off the quote from everything you type btw
Sera
RichardK
posted on 1/11/05 at 09:14 PM |
Any reason that you haven't installed sp2 and use use it's built in security centre, firewall, it obviously supports sharing and
isn't all that bad.
Rich
Gallery updated 11/01/2011
esn163
posted on 2/11/05 at 07:45 PM |
XP Pro SP1
ZoneAlarm's pretty good once you get any network places or other computers on the network set up as trusted or it won't allow file
sharing.
link
Ed
[Edited on 2/11/05 by esn163]
