Author: Subject: file transfer on network?
john_p_b
posted on 29/1/06 at 08:56 PM Reply With Quote
as title really, got my wireless network set up between my laptop and my folks pc downstairs. how do i transfer files between the 2? i can see how to share them but that only allows them to be viewed and not saved to the other pc?
built a car, built a home, had a family. lost the family, lost the home, still got the car.
RichardK
posted on 29/1/06 at 09:02 PM Reply With Quote
Not quite sure what you mean, can you view each of them in my network places and drilling throught entire network so you can see each others shared hard drive? If you can you can drag into each window or just copy and paste.
All comps have the same workgroup name but differnet static ip's 192.168.0.1 & 192.168.0.2 mask 255.255.255.0
Think we need a bit more info on the config of your network.
mookaloid
posted on 29/1/06 at 09:20 PM Reply With Quote
sounds like a permissions issue to me - it's in the properties of the shared folder (right click - have a poke about)
HTH
Mark
CommanderAce
posted on 29/1/06 at 10:31 PM Reply With Quote
Here follow this.
mark chandler
posted on 29/1/06 at 11:58 PM Reply With Quote
Assuming you have not got XP, like me you will need an FTP or TFTP server (surf a free one from the WWW ) on one box to set up a FTP connection.
You can then PUT or GET files from the dos prompt.
An alternative is transfer files using MSN messenger as a carrier.
Regards Mark
[Edited on 29/1/06 by mark chandler]
britishtrident
posted on 30/1/06 at 08:59 AM Reply With Quote
Regards Mark
All versions of Windows since Windows for Workgroups 3.11 (circa 1992) allow users to share files and directories and printers across a Windows network without the need to run an FTP server. All that is required is to enable file sharing, then share the directory
Also even if you use FTP for the actual file transfer there are loads of free GUI program (such as FileZilla http://filezilla.sourceforge.net/ ) to allow painless file transfer without going near the dos prompt.
[Edited on 30/1/06 by britishtrident]
britishtrident
posted on 30/1/06 at 09:03 AM Reply With Quote
Agree with mookaloid on this one also check user names and passwords exist on both PCs.
