Author: Subject: Windows Shutting down on it's own
Jasper
posted on 2/12/06 at 02:40 PM Reply With Quote
At least a couple of times a day Windows is shutting down on it's own - been doing it for a few days now. I've spoken to at least 2 other people who's PC's are also doing this, and it's a new thing.
Any thoughts? Virus or Windows update?
I have AVG free and Adaware Pro installed and sit behind a firewalled router.
Otherwise everything is running fine.
martyn_16v
posted on 2/12/06 at 02:45 PM Reply With Quote
Is it giving you any kind of warning, or a blue screen of death? Try looking at the event logs (right click on my computer, click manage, and then look in the application and system logs under system tools->event viewer) for any warnings or errors at the time the pc has reset itself. You can usually google the event/error codes to get an idea what is going on.
Jasper
posted on 2/12/06 at 03:00 PM Reply With Quote
No warning - no error, it's like I hit the reset button, programmes close and you get a proper Windows Shutdown screen. I don't think Outlook closes properly though, as on re-boot it does a data check.
oily85
posted on 2/12/06 at 03:09 PM Reply With Quote
Have you got a keyboard with a shutdown/sleep key on it?
My Aunt's computer did this, got sent back 3 or 4 times, and they couldn't find the fault, turned out to be a fault with the keyboard shutdown button, swapped the keyboard and it was fine.
flak monkey
posted on 2/12/06 at 03:12 PM Reply With Quote
Win XP has an option to auto reboot on a 'fatal' error. You can turn it off though and I cant remember where the option is at the moment. Google will probably yeild the answer tho.
Sera
http://www.motosera.com
Jasper
posted on 2/12/06 at 03:28 PM Reply With Quote
It's does have a sleep key, but I've tried it and it just hibernates, and comes back to where you were straight away, which is not what it's doing.... worth a try though, thanks.
And I'll have a look on Google for the fatal error shutdown...
OK - just checked, I don't have Automatic Shutdown set anyway, so it shouldn't be a fatal error doing this, I would get a warning....
Any other thoughts?
[Edited on 2/12/06 by Jasper]
martyn_16v
posted on 2/12/06 at 04:06 PM Reply With Quote
some services can reboot if they encounter an error, but you should see if this is happening in the event logs
Jasper
Where's the events log?
RazMan
posted on 2/12/06 at 04:14 PM Reply With Quote
I had a system doing similat things recently - it turned out to be the heatsink needing some heat transfer compound reapplied. The processor was getting a bit hot and having a hissing fit.
Raz
ecosse
posted on 2/12/06 at 05:37 PM Reply With Quote
If you are sure you are virus free (there are quite a few that can cause a shutdown) then the best bet (as razman says) might be an overheat condition.
Oulook will complain in this instance as it has been a forced shutdown and has not exited gracefully.
You could try running a monitor program to keep an eye on temps as a starting point.
Alex
mackei23b
posted on 2/12/06 at 05:51 PM Reply With Quote
Blaster worm does this with XP!
Hellfire
posted on 2/12/06 at 08:45 PM Reply With Quote
Also difficult (was impossible at one time) to get rid of....
Catpuss
posted on 2/12/06 at 09:46 PM Reply With Quote
Doesn't happen to be a Dell at all?
GX270s amongst a few others are a sod for the capacitors around the CPU swelling up (or apparently bursting in some cases). Usually the PC shuts down with the green power light still on.
iank
posted on 2/12/06 at 10:49 PM Reply With Quote
Wasn't just dell. There were a large number (many millions) of faulty electrolytic caps around a while back. Turns out someone nicked a secret formula for the electrolyte from another manufacturer but got it wrong and the caps swell up and explode after a while, it would be funny except for all the motherboards and graphics cards that have failed.
See http://www.badcaps.net/ for the whole sordid story.
Jasper
posted on 3/12/06 at 04:22 PM Reply With Quote
It's under warranty - I'll give Dell a call - thanks chaps
Catpuss
posted on 4/12/06 at 08:15 PM Reply With Quote
Ah bingo. Last time I phoned them up for PCs the tech guy said : "PC shutting down", I said "yep", he then said "Capacitors burst yet" and I replied "Not yet". And that was it for diagnosis. New board the following day.
Jasper
posted on 5/12/06 at 03:15 PM Reply With Quote
Seems to have stopped doing it for now...... I'll call Dell when I have an hour spare
