Slater
| posted on 1/2/07 at 08:29 PM |
problem with CDRW drive not spinning
Hi, my DELL desktop has a DVD/CDRW drive, it will spin and work OK for CD's with basic data on them (jpeg files), I can also burn CD's
OK......... but if I insert a software installation disc/game or even the CD lens cleaner disc it will even not spin the disc.
Any suggestions? Please reply in basic english as I am not very computer literate.
Keith.
flak monkey
| posted on 1/2/07 at 09:07 PM |
Have you inadvertently turned auto run off?
If so to re-enable it go to:
My computer> right click drive > properties >autoplay > and click the restore defaults button
Should fix it.
I assume you are using Xp, if not its a bit more complicated.
Sera
http://www.motosera.com
Slater
| posted on 1/2/07 at 10:19 PM |
Thanks for reply David. I tried that, it's allready on the default setting. No change.
A disc with files on it will spin stright away, but any software disc won't spin at all.
I am running XP.
Any other suggestions?????
Jubal
| posted on 2/2/07 at 01:04 AM |
What happens when you browse to the drive?
Slater
| posted on 2/2/07 at 08:54 AM |
It does recognise the drive, and will show any files if the CD is one that I burned myself (photos/back-up files etc.) But if it's a software
disc then the drive just clunks about 6 times and that's it.
| posted on 2/2/07 at 10:12 AM |
Go into control panel and delete it then let windows find it again and reinstall it. It's worth a try. Do you have more than one user on the
accounts, need to sign in as administrator?
D Beddows
| posted on 2/2/07 at 10:39 AM |
I've just had an almost identical problem with the CD/DVD drive on my Dell, decided that as you can buy a new one for less than £30 it
wasn't worth mucking about with. Piece of cake to swap them over.
Slater
| posted on 2/2/07 at 11:29 AM |
hmmmm think I'll call the dell helpline tonight. Seems strange that it's OK with some CD and not with others. Thanks for yer help!
Jubal
| posted on 2/2/07 at 12:46 PM |
Are you still in warranty on your Dell? Then let them sort it. Otherwise, what they said above is good advice. If all fails, buy a new one, internal
drives are dirt cheap. Unplug the old, plug in the new and away you go. The hardest part is usually opening the case!
Slater
| posted on 13/2/07 at 05:14 PM |
I call Dell helpline, they called me back and spent 1 hr on the phone. Then concluded it was a hardware problem, so sent me a new drive the next day
for free (3 yr hardware warrenty with Dell). Problem solved!!!
Even had 2 further calls checking if the problem was sorted.
Excellent customer service.
