clairetoo
| posted on 8/6/08 at 06:48 AM |
Laptop `power` plug ?
I need to run my laptop (an old Toshiba Satelite Pro) in my car for mapping , I`ve bought a power supply to plug into a fag lighter socket , but
although it comes with a range of plugs theres not one that fits
I did `bodge` the nearest fitting one , but the tiny pin inside broke off , leaving me a bit stuck
Anyone know where I can buy just the plug to suit , or better still got a dead mains adapter hanging around that I could scroung the plug off ?
Its 6.5mm outside , with a 3mm center hole .
Its cuz I is blond , innit
Claire xx
Will weld for food......
Macbeast
| posted on 8/6/08 at 07:32 AM |
My laptop, the pin is in the computer end, not the adaptor. If the pin is broken do you not need to replace the lappy socket ?
It's cuz I is bald innit
[Edited on 8/6/08 by Macbeast]
clairetoo
| posted on 8/6/08 at 08:19 AM |
The socket is fine - the nearest plug that came with the power supply had a small pin inside which I bent to make it work - till it broke off
Claire xx
Macbeast
| posted on 8/6/08 at 06:44 PM |
Maplin FM47B
6.5 / 3.1
Should do at 89P
I may have one but measuring thingy is at the garage. If you don't have a handy Maplin send U2U with address and I'll get you one to
try.
Are you blonde enough to need telling you have to get the polarity right ?
clairetoo
| posted on 8/6/08 at 09:11 PM |
Cveers Macbeast - U2U sent
PS - wots polarity ?
Claire xx
