spunky
posted on 21/6/04 at 09:00 PM |
scanners.....
I need to send off some documents via e-mail (bank statements, gas bill etc)
Scanned said documents and attach to e-mail ok, but when printing the attachment the quality so poor they a virtually illegible.
Scanned using OCR also converted to BMP image rather than JPEG. Increased resolution. Tried copy/pasting to various other programs but still cack.
Is there a way of doing this, or is it just one of them things that screws a PC since it treats a simple text doc. the same as a hi-res photo?
Any one help... BTW I'm a hairy arsed engineer, not an IT boffin, so nothing to complicated.
Oh yeah, I can't fax direct, I don't have a land line.
John
The reckless man may not live as long......
But the cautious man does not live at all.....
posted on 21/6/04 at 09:11 PM |
I depends on the resolution of your scanner - it sounds like you're scanning resolution is 72dpi which is the dpi that screens display in. To
print in a reasonable quality 200dpi is normally acceptable, set colour to black/white (not colour or greyscale as filesize is quite large).
Hope this helps.
flak monkey
posted on 21/6/04 at 09:12 PM |
Scan them using something like photoshop. Scan at a resolution of about 250-300dpi and use grey scale. Thats how i scan documents, they are easily
readable and the files are still pretty small.
(Dont bother with OCR unless the page is just plain text like in a book. It gets too confused with forms, small text and logos.)
Hope that helps,
[damn beaten to it ]
[Edited on 21/6/04 by flak monkey]
Sera
http://www.motosera.com
spunky
posted on 21/6/04 at 09:20 PM |
Thanks guys,
Been scanning at 300dpi, which is overkill.
I'll try Photoshop.
John
Note to Flatmonkey,
have you tried typing "the shocker" into google. It explains what the young lady in your avatar is suggesting....
[Edited on 21/6/04 by spunky]
SteveO
posted on 21/6/04 at 10:10 PM |
Hi
If you scanned using OCR you should be able to save it in word which will be clear to fax. do not save as .bmp or jpg
posted on 22/6/04 at 06:40 AM |
Depends a lot on the scanner and software some scanners don't work well with standard twain drivers. OCR I have always found a waste of time
unless you are scanning a lot of almost identical documents.
Try scanning at 150 to 200 DPI in black and white -- Microsoft Imaginging gives lousey results so I use Paint Shop Pro for this.
Tip not connected directly with original question --- anyone buying a scanner for home/SOHO use look at a Hewlett-Packard all in one printer-scanners
much better than the oposition - very reliable, decent scans and copies and faster than most other printers-scanners at the same price only downside
is cost of cartridges.
Another tip for normal use remove any OCR software from a PC as even sitting as a stub waiting to be called it uses a lot of system resources.
[Edited on 22/6/04 by britishtrident]
spunky
posted on 22/6/04 at 07:41 AM |
sorted.
Reckon I've cracked it. Scanned at 200dpi using Photosuite in B&W. Much of the quality of the print out seems to depend on the program used
at the other end. Opened and printed using Windows fax viewer and the quality is shocking, use a photo specific program and it's pretty good.
Now got to send copies of passport and driving licence...! all this to get a new car for the girlfriend, MX5 so should be worth it. Yes she is a
hairdresser
Thanks all for the help
John
pbura
posted on 22/6/04 at 11:18 AM |
I have one of these (an 1100A), and can endorse BT's comments. I use it as a fax machine and small-scale copier. It comes with a desktop
utility that's very handy for editing and sorting scanned pages, adding annotations, etc.
Another downside is the paper feder mechanism (on the printer portion) is subject to wear and wants to grab multiple sheets if the paper tray is not
full.
Re: OCR - Flawlessly accurate with numbers but weak with letters, even if spacing is fixed. I use it for converting long printed lists and reports to
Excel spreadsheets, and it's indispensable for that purpose.
Pete
