mcerd1
posted on 31/8/11 at 09:01 AM |
OT - SATA to USB thingy
can some one recommend me a USB adapter thingy for SATA drives (2.5" and 3.5" )
not bothered about any kind of case, but it would be best if it was powered off the USB cable
cheers
-Robert
[Edited on 31/8/2011 by mcerd1]
HowardB
posted on 31/8/11 at 09:20 AM |
got mine from Maplin, not sure that there are any that are USB powered ones, but mine came with a nice PSU,....
£25 if I recall,....
hth
Howard
Daddylonglegs
posted on 31/8/11 at 09:46 AM |
I got one of 2.5 inch SATA HDD to USB 2.0 Enclosure Caddy -02 | eBay. I am assuming you have the drive, just need the
adaptor right?
I'm happy with the one I have and it takes it's power from the USB port.
HTH
JB
stevebubs
posted on 31/8/11 at 10:17 AM |
2.5 inch will probably be able to be powered from USB port; doubt a 3.5inch one will....
stevebubs
posted on 31/8/11 at 10:18 AM |
http://www.amazon.co.uk/Sumvision-Sata-Docking-Station-Reader/dp/B002AGWNSY
jossey
posted on 31/8/11 at 10:19 AM |
just buy a cheap one on ebay. they are about £5.00
get usb 2.0 as its a bit quicker. but all are simular and do the job.
I have 3 or 4 drivers now which all work well and all have different enclosures.....
dont worry abotu specific makes as most are re branded anyway.
good luck,
David Johnson
posted on 31/8/11 at 10:31 AM |
You can't power a 3.5" drive from a USB port, and it's marginal with some 2.5" drives (many enclosures come with a cable to
draw power from two USB ports to ensure it works).
balidey
posted on 31/8/11 at 12:33 PM |
I would say DON'T buy the absolute cheapest one off ebay. I did and it didn't read the drive. It powered up, the drive letter appeared,
but no access. Same on several drives and several PC's.
Then bought a very slightly more expensive one, about £10, made by (or badged as) Dynamode and that worked as it should.
Dutch bears have terrible skin due to their clogged paws
Madinventions
posted on 31/8/11 at 12:34 PM |
If you want to change drives frequently then a case is a PITA. Do an eBay search for 'USB 2.0 TO SATA / IDE CABLE FOR HDD W/ POWER ADAPTER
UK' (ie Item number: 320383801768)
This is an in-line cable mounted adaptor that works with 3.5" IDE, 2.5" IDE and all SATA drives, and includes a power supply so you
don't have to power the drive from USB. It also comes with all the leads you need, and it's only £9 with free postage.
Oh, and it works with Windows 7 64 bit (unlike some of the cheaper Chinese tat!)
Ed.
View my band website:
http://www.shadowlight.org.uk
mcerd1
posted on 31/8/11 at 12:49 PM |
cheers guys, the more options the better
yeah I've got a cheap old 2.5" PATA one like that (similar to the one in Daddylonglegs's link)
but somehow I've never had an issue with getting the power from a single plug - I guess all my machines have good USB ports
looking at the options I might just get a cheap 2.5" cased one (and not use the case most of the time )
the big drives can easily be shoved into whichever pc I'm working on
posted on 31/8/11 at 03:11 PM |
Or your 2.5" drives have fairly low power consumption. The some of the 5400RPM and 7200RPM laptop drives didn't like being powered from a
single port.
Desktops are much less of a problem than laptops as well.
[Edited on 31/8/11 by MikeRJ]
Phineas
posted on 31/8/11 at 03:17 PM |
If you're swapping drives frequently, or have both 2.5 & 3.5 drives to use...
http://www.aria.co.uk/Products/Components/Drive+Enclosures/External+(For+SATA+Drive)/CnM+3.5%22+%26+2.5%22+SATA+Docking+Station+?productId=33969&s
ource=googleps
Works well (Windows 7)
