Author: Subject: twin monitor set up
mookaloid
posted on 24/1/12 at 09:29 PM Reply With Quote
twin monitor set up
Trying to assist a relative with installing a twin monitor set up. she uses it for work - she is a copy editor and needs to get a second monitor for all the windows she has open. The monitors need to be DVI input for quality and obviously she needs them to work in extended desktop mode not 2 monitors showing the same thing.
So I have found a pair of suitable monitors but I am struggling with the graphics card thing. I need 2 DVI outputs but I can't find a reasonably priced dual dvi card which fits in her pc. She has one of those daft mini pc things so can only use a low profile graphics card. it is a pci-e slot.
I have seen this HD2400XT Low Profile PCI-E 256MB Gaming Video Card with Dual DVI Splitter Cable | eBay -will this do the trick?
I assume that I can't just use a DVI splitter cable on her existing 1 DVI port card and achieve the extended desktop?
Thanks in advance
Mark
McLannahan
posted on 24/1/12 at 09:41 PM Reply With Quote
Mark - I've just bought one of these today to do the same thing for a member of staff. It's an external graphics card and has a DVI output but comes with an adapter for VGA too. USB2. PLug in - driver - job done!
http://www.ebuyer.com/247097-ezcap-usb-to-dvi-vga-adapter-output-usb-to-a-second-monitor-ezcap808
mookaloid
posted on 24/1/12 at 09:59 PM Reply With Quote
Looks dead easy - did you see it working? is the quality as good as direct from the graphics card DVI?
dhutch
posted on 24/1/12 at 10:12 PM Reply With Quote
Although in every way twin DVI makes the most sense, im running twin 19" monitors with one on DVI and the other on D-SUB and i would challenge anyone to notice which was which.
At work they have twin HDMI output cards, which is probably where its going now. HDMI contains the same info as DVD-D, just in a different physical connector and you can adapt between the two with simple adapters.
- HDMI also allows audio, but cannot contain analog signals as DVD-I or DVD-A can.
Then i use ultramon to sort out my task bars (one foe each screen) as XP is crap at it, but later OS' may be better.
Daniel
McLannahan
posted on 24/1/12 at 10:16 PM Reply With Quote
It should arrive tomorrow so i'll post an update! I use something similar ( same device but different brand) with a laptop and it's spot on, easy and no hassle.
James
posted on 24/1/12 at 11:26 PM Reply With Quote
My father finally tired of the twin 21" CRT monitors he was running and bought a single flat screen from Dell.
It's about 40" widescreen (I'd ask full details but he's in NZ for another 3 weeks!) and I think you can now get them for around £400.
The picture is utterly stunning.
He's no gamer (apart from patience/mahjong ) so it won't be on a pricey gaming graphics card.
James
stevebubs
posted on 25/1/12 at 08:48 AM Reply With Quote
http://www.novatech.co.uk/products/components/nvidiageforcegraphicscards/nvidiagt520series/90-c1cqq0-l0uanayz.html
Check it supports use of HDMI And DVI At the same time
Then use an HDMI-DVI converter..
stevebubs
posted on 25/1/12 at 08:49 AM Reply With Quote
James
1 word: Resolution ; especially if you're working with text day in / day out.
Twin 21/22in flatscreen monitors would be a world apart from twin 21" CRT...
stevebubs
posted on 25/1/12 at 09:13 AM Reply With Quote
If it's the same as the Gigabyte one then it will support (HDMI->DVI)+DVI using converter
http://download.gigabyte.ru/manual/vga_manual_n520oc%28tc%29-1gi_e.pdf
[Edited on 25/1/12 by stevebubs]
jossey
posted on 25/1/12 at 09:42 AM Reply With Quote
most cheap nvidia cards have two dvi outputs.
You can pick up second hand cards for like £20.
then plug and play really.
David Johnson
McLannahan
posted on 25/1/12 at 03:00 PM Reply With Quote
Arrived this morning. Had it up and running within about 10 mins. Comes with DVI to HDMI too which was a bonus.
Seen as a second graphics card by Windows and then supported as such. Can clone display, duplicate or extend.
I have the primary display connected on VGA and this second display is through the USB DVI. It's indentical Mark - no degrading, lower res etc... It's a perfect extended image and 100% the same as the onboard device.
True you can easily get cards with dual outputs but this was an easy, cheap (ish) solution and one that I can move to any PC/Laptop/Mac/Linux box when she's finished with it. No installation involved - just plug in and run the setup on the CD supplied.
mookaloid
posted on 31/1/12 at 07:05 PM Reply With Quote
thanks mate I'll recommend it
