Author: Subject: Is it possible to recover a WEP passkey?
Rek
posted on 17/10/07 at 12:15 PM Reply With Quote
Just wodering if it's possible to work a WEP passkey backwords to discover the word that was used. Since my brother in law died last year we've left the network alone as it's just worked... but his eldest has a nintendo DS and this seems to want a 13 character WEP key unlike the laptop(s) which both used the HEX numbers on the router...
I could get them to re setup the router but Im worried about trying to get them to do this and it going wrong (they are in Aus and Im not!!) and when you look online all it seems to talk about is hacking wireless etc..
[Edited on 17/10/07 by Rek]
RichardK
posted on 17/10/07 at 12:18 PM Reply With Quote
Have you tried the hex key you have? or have you tried convert that hex into ascii.
But to answer your question, not that I know of, probably 128 bit so would take a while anyway.
Rich
Just found this which seems wierd as yours is only 13 digits long
Should I use HEX or ASCII when creating a WEP Key?
When entering a WEP Key, you have the choice of entering Hexadecimal or ASCII characters. Hexadecimal (HEX) is the easiest to use. You can either create a 10-digit (64-bit) or 26-digit (128-bit) key. We recommend the 10-digit. Consider using an easy-to-remember number.
[Edited on 17/10/07 by RichardK]
Gallery updated 11/01/2011
Rek
posted on 17/10/07 at 12:20 PM Reply With Quote
Yeah tried but there's not enough room to type the numbers into the DS.
04:05:00:44:12:04:05:00:44:12:25:06:66
perhaps Id better just try and re-set it. or get telstra to talk them through it!!!
posted on 17/10/07 at 12:22 PM Reply With Quote
Off chance you may find the key on a sticker on the bottom of the router.
or
Use a cable connection to connect to the routers setup page and change the key.
RichardK
posted on 17/10/07 at 12:25 PM Reply With Quote
Maybe the ds can only support 64 bit encryption and your router is set up for 128?
Hence not having enough space. Somebody should be along soon that has more knowledge on ds's
R
ned
posted on 17/10/07 at 12:31 PM Reply With Quote
Done this myself.
connect via cable
do an ipconfig/all
put the gateway ip address in a web browser, login to the web console
change the wep passkey and re-enter the new one to all connected devices..
Ned.
beware, I've got yellow skin
saigonij
posted on 17/10/07 at 01:12 PM Reply With Quote
type it in without the ":".
andyharding
posted on 17/10/07 at 04:18 PM Reply With Quote
Yes you can find out someones WEP key but it's not easy.
posted on 17/10/07 at 05:19 PM Reply With Quote
Aircrack -- always wanted to try it.
joneh
posted on 17/10/07 at 05:31 PM Reply With Quote
Would be easier to connect to it with a cable - most people leave there router passwords as "admin". If its a sky router it'll be "sky" etc etc.
Of course only 1337 h4x0rs know this.
posted on 17/10/07 at 06:22 PM Reply With Quote
You couldn't hack your way out of a wet chip bag
stevebubs
posted on 17/10/07 at 07:50 PM Reply With Quote
WEP ascii <--> hex Translator Tool
stevebubs
posted on 17/10/07 at 07:51 PM Reply With Quote
Rich
Original DS Link
oadamo
posted on 17/10/07 at 08:53 PM Reply With Quote
you have to port from windows to Linux thats the hardest part trying to get the card working. and you need a card that will run in mon mode. linksys a/b/g cards with atheros chipsets in off ebay work very well. but its easy to do if you have everything you need.
adam
Rek
posted on 18/10/07 at 01:15 PM Reply With Quote
Good news is that trying the passkey without the colons did the trick. thanks all for your help :-)
posted on 19/10/07 at 07:07 PM Reply With Quote
adam
No it is available as a Win32
