a4gom
posted on 17/7/08 at 02:51 PM |
using back button when searching
When I do a search, have a look at one of the results then click the back button to return to the search results I always get a message saying
something about "you are trying to ... postdata... click ok or cancel", if I click cancel nowt happens just stay on the same page, if I
click ok I'm back to the blank search input page .
I know I can get round it by opening each result in a new tab but sometimes I forget and its kin annoying.
Is it me, something i'm doing or is it like this for everyone? It doesn't happen on the other forums I visit.
Perfect planning prevents pi$$ poor performance!
Mr G
| posted on 17/7/08 at 02:57 PM |
Works fine here, If you go back you get a 'warning page has expired' - then hit refresh and click 'retry' when the box pops
up.
Stuart_B
| posted on 17/7/08 at 03:02 PM |
up.
i just do what Mr G said. as i forget to open them i different tabs.
stuart
I right click on the submit and select 'Open link in new window'
That way when i want to go back i just close that one off and the search results are still there
I'm using Mozilla BTW.
mr henderson
| posted on 17/7/08 at 03:06 PM |
No, it isn't just you, I get the same thing too.
I will try the tricks the others have mentioned
John
chrism
| posted on 17/7/08 at 04:41 PM |
If you have a mouse with a scroll wheel that also acts as a middle button by pressing on it you can use that on the links and it will open stratight
into a new tab in IE7.
A little hard work never killed anyone, but why take the risk!
stevebubs
| posted on 17/7/08 at 05:54 PM |
An alternative search function can be found here
[Edited on 17/7/08 by stevebubs]
stevebubs
| posted on 17/7/08 at 05:55 PM |
I never knew that - works a treat!
Ivan
| posted on 17/7/08 at 07:20 PM |
^^^^Ditto - thanks
oldtimer
| posted on 17/7/08 at 07:41 PM |
This site is soooo usefull - I didn't even realise my scroll wheel was a button too until now!
