Author: Subject: Spybot - Search & Destroy
posted on 30/11/08 at 07:34 PM Reply With Quote
I have Spybot - Search and Destroy installed (version 1.5.2) Previously, a complete scan used to take about 40 minutes but for the last few weeks, a full scan now takes just over 3 hours
Anyone else using it and noticed this too?
Phil
matt.c
posted on 30/11/08 at 07:44 PM Reply With Quote
I used mine the other day and it didnt take long. Will try again and see what happens...
Howlor
I'll try mine later for you, it normally takes 45mins to run fully so should be comparable.
Fozzie
posted on 30/11/08 at 07:53 PM Reply With Quote
Phil,
The latest version is 1.6.0.31......
I usually find it takes around 40-ish minutes. however, it can take longer if you have stuff you are looking at/working on...that is to say, programmes/browser open and running.
HTH Fozzie
posted on 30/11/08 at 10:36 PM Reply With Quote
OK, just ran CleanUp, did a defrag and am currently doing a scan on Spybot - S&D, which has taken two hours so far. One thing I have noticed is a very large amount of files under the heading of Virtumonde.sdn
After googling "Virtumonde.sdn" I'm not liking the results I'm reading..............
Phil
omega0684
posted on 30/11/08 at 10:41 PM Reply With Quote
how do you put it in administrator mode?
Fozzie
posted on 30/11/08 at 10:53 PM Reply With Quote
Phil,
Virtumonde.sdn = Trojan
Update to the latest 'free' SpyBot S&D once sorted.... they usually release the latest threats on Wednesdays/Thursdays.....don't forget to immunise once you have downloaded the latest database updates.
Good luck....
Fozzie
posted on 30/11/08 at 10:59 PM Reply With Quote
I don't know. Never needed to do it before...
Phil
