grazzledazzle
| posted on 6/12/08 at 02:35 PM |
Looking for the cheapest new laptop in the world?
I want a very cheap laptop for running mapping software only really. I use macs normally but need one for the garage work. Any suggestions? Nearly new
considered if anyone has something very cheap? Will give it to girlfriend when i have finished for web use only.
mcerd1
| posted on 6/12/08 at 02:44 PM |
what about this kind of thing:
http://www.asus-uk.com/eeepc/about/
Myke 2463
| posted on 6/12/08 at 02:46 PM |
cheap laptop
Try /www.callright.co.uk/ they will look after your needs.
splitrivet
| posted on 6/12/08 at 03:14 PM |
What do you need exactly, what operating system, harddrive size etc.
Ive got a couple of old tosh satelites knocking about you can have for much cheapness.
Bob
tegwin
| posted on 6/12/08 at 03:16 PM |
If your just after something for the garage to do mapping stuff you might as well check out Ebay....
Find something older that will run XP and has a serial port...
You should be able to get something more than useable for £150..... get one of the bigger brands and getting spare parts on ebay is easy
www.verticalhorizonsmedia.tv
mark chandler
| posted on 6/12/08 at 03:59 PM |
I,ve got an old thinkpad that I use with it came with a knackered battery.
Just run a cable from the car battery and its okay, these are pretty robustly built which you need as lots of jostling and bashing when you are on the
move.
grazzledazzle
| posted on 7/12/08 at 10:21 AM |
Cheers chaps. Think i'm sorted.
