Author: Subject: Time date change on start up
bob
posted on 13/12/08 at 09:58 AM Reply With Quote
For the last 3 days my PC at home has decided not to play ball, on start up i get a screen of options set up or default settings which ends up with the reset button and eventual start up. Then the date reads 5 nov 2003 00.00hrs which is probably the initial start up date of the pc when new or first configured,a change of date and time and all is ok.
My question is why ?
And what can i do get back to normal start up ?
[Edited on 13/12/08 by bob]
mcerd1
posted on 13/12/08 at 10:02 AM Reply With Quote
the CMOS battery will be dead
thats the little one on the motherboard (its often a CR2032 - but check before buying)
paul the 6th
posted on 13/12/08 at 10:12 AM Reply With Quote
aye, tiny little battery which keeps all the basic settings for the computer such as date and time...
It could be your alternator which has gone if the cmos battery isn't charging up... Or maybe even the distributor?
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
bob
posted on 13/12/08 at 10:19 AM Reply With Quote
I've already changed the alternator dizzy and leads
Cheers lads i have a large packet of CR2032's it will give me something to do today
mcerd1
posted on 13/12/08 at 11:01 AM Reply With Quote
just make sure its not an odd one with a CR2023 or something else
bob
posted on 13/12/08 at 12:13 PM Reply With Quote
Checked out as a CR2032 so plenty of them in stock, i decided to give the box a good hoover out while i was at it
thanks again lads
