speedyxjs
| posted on 7/2/09 at 10:13 AM |
Strange happenings - Monitor
This morning i switched my pc on and the monitor had white 'snowy' lines across it. I fitted my old graphics card, no different. I went
out and brought a new lead to my monitor still no change, so this lead my to beleive it was my monitor given up. I unplugged it,, blew dust out of it
(there wasnt much) and plugged it in just to see if that had helped and amazingly it had but now the picture is blurry and im typing this thinking im
drunk.
Could it be anything else? My dad is bringing a monitor home from work but if that doesnt help, i dont know where else to look.
Worse part is, the monitor is only 2 yrs old
jlparsons
| posted on 7/2/09 at 10:18 AM |
Think it's had sex. (f@@ked)
Is it a crt or lcd?
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during
shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to
approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable
parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television.
Keep cool; process promptly.
speedyxjs
| posted on 7/2/09 at 10:19 AM |
Nice way of putting it^^^
Its LCD
Mark Allanson
| posted on 7/2/09 at 10:33 AM |
Check you don't have any bent pins in the connector, I had a similar thing with mine but some careful teasing with a small screwdriver cured it
speedyxjs
| posted on 7/2/09 at 10:36 AM |
No bent pins
l0rd
| posted on 7/2/09 at 10:38 AM |
try playing with the setting on windows. Change resolution, play with the refresh rate.
Simon
| posted on 7/2/09 at 10:56 AM |
I can't help, but the "only 2 years old" bit made me smile.
My Gateway monitor popped 13 days after 1 year warranty expired. Asked if they'd like to fix it they suggested that er, no. Needless to say, I
wil never touch another Gateway product
As it happens, that was just an internal fuse.
Simon
speedyxjs
| posted on 7/2/09 at 11:14 AM |
Just fitted new monitor from work and it works perfectly. Im off to buy a new monitor.
Benzine
| posted on 7/2/09 at 11:54 AM |
In some flatscreens I've had I "pinch" the plastic frame around the edge and that helps. Also they often have a degauss equivalent
as CRTs have that reset/sort out the image.
jlparsons
| posted on 7/2/09 at 01:30 PM |
Before you actually bin it, take it apart and wiggle all connections. Disconnect and reconnect anything that's not soldered in. Might work,
nothing to lose! Worked on my old CRT monitor many years ago.
And if it doesn't, at least a bit of aggressive disassembly will make you feel better.
Caveat: make sure you've absolutely definitely tried everything else you possibly can first, and don't sue me.
[Edited on 7/2/09 by jlparsons]
