mookaloid
| posted on 7/2/09 at 03:17 PM |
HDD reliability
I'm coming across several failed hard drives recently - Western Digital and Samsung being the 2 most recent.
Which makes are the most reliable?
Mark
ReMan
| posted on 7/2/09 at 04:18 PM |
Are you talking about Desktop or Laptop drives?
Dangle_kt
| posted on 7/2/09 at 04:20 PM |
proper cooling helps, heat often kills an otherwise reliable brand.
dhutch
| posted on 7/2/09 at 04:50 PM |
We have about 5-6 Seagates on the go around the place, two in this machine, and so far have been fairly happy.
- Only ever had one die, which was a 11gb Fujitsu about 8 years ago.
These are pata and sata desktop drives.
Daniel
flak monkey
| posted on 7/2/09 at 05:01 PM |
I have had an 80Gb IBM drive for about 8 years now, still going strong. My newer drives have all been Maxtor or Seagate Barracudas, all of which have
been faultless.
Having said that all of mine are sitting behind a good fan which is regularly cleaned.
Sera
http://www.motosera.com
graememk
| posted on 7/2/09 at 05:35 PM |
i always build with maxtor and if you keep them coolish you wont have a problem.
but to be honest they arnt as reliable as they used to be, change more psu's and hard drive now than ever before
mookaloid
| posted on 7/2/09 at 05:44 PM |
The WD was a desk top 3.5"
The Samsung was a 3 month old 2.5"
mookaloid
| posted on 7/2/09 at 05:45 PM |
Good point - I hate noisy PC's I have been known to disconnect the case fan to keep it quiet
martyn_16v
| posted on 7/2/09 at 06:45 PM |
I've never had a Seagate fail on me, and I look after a lot of machines
mcerd1
| posted on 7/2/09 at 06:57 PM |
I've used seagate disks in everything for the last 7 years in all the machines I've built/ fixed for myself and the family (about 20+
disks) and so far none have failed so far (the first one I got is still going in this machine I'm using now)
but I've had a WD and 2 Fujitsu's that both failed at about a year old
I was running my main disk in a big alloy heatsink thing (with a fan built in) that fitted in a 5.25" bay and I could do with a couple more of
these, but I can't find anywhere that sells them now - anyone know where you can get them ?
| posted on 7/2/09 at 07:10 PM |
I wasn't sure what HDs I'm running so I just looked....
3* Maxtor drives.
1 is 10 years old, 1 is 6 years old, one is 2 years old.
None have every had any errors.....
So I can firmly recommend Maxtors!!!!!!
mcerd1
| posted on 7/2/09 at 07:22 PM |
Maxtor are made by seagate
BenTyreman
| posted on 7/2/09 at 07:55 PM |
http://www.theinquirer.net/inquirer/news/374/1050374/seagate-barracudas-7200-11-failing
mookaloid
| posted on 7/2/09 at 08:38 PM |
Damn I just ordered a seagate
