stephen.holdcroft
posted on 20/3/09 at 01:22 PM |
zzr1100 gearbox
hi, can any one help i have just noticed that the out put shaft appears to have a bit of end float. Any one know if this is normal or is something
loose in the gaerbox?
Paul TigerB6
posted on 20/3/09 at 01:27 PM |
Sounds like a bearing to me (not knowing the engine though). Which way is the float? Up / down etc or in and out of the box?
posted on 20/3/09 at 01:44 PM |
End float = in/out... worn thrust washer somewhere inside maybe??
ReMan
posted on 20/3/09 at 03:45 PM |
I would expect that it's normal
Guinness
posted on 20/3/09 at 07:16 PM |
How much play have you got in the shaft?
If you can measure / describe the direction of play a bit more I can compare it to mine.
Mike
stephen.holdcroft
posted on 20/3/09 at 08:44 PM |
end float
The float is along the line of the shaft in and out, I would say 4 mm which i think is a lot. although the engine runs ok with no noise. it only came
to my attention when i bolted on the new prop.
Guinness
posted on 24/3/09 at 10:39 AM |
Hi Stephen
I've just been out and checked mine. No end float at all on the output shaft.
I've checked the manual too, and it doesn't give a tollerance either.
Sorry.
However, I do have two complete spare gearboxes if you need them, plus all the bearings etc.
Let me know if you need anything.
Mike
Guinness
posted on 24/3/09 at 08:07 PM |
Just thinking, is it definately the output shaft moving?
When I first fixed my prop adaptor on, the nut wouldn't lock it in place. The thickness of the adaptor was a couple of mm less than the splined
length on the output shaft. So I have a spacer washer inside and an extra lock washer on mine.
Mike
stephen.holdcroft
posted on 25/3/09 at 08:45 PM |
gearbox
will look at this over the weekend, I hope that is the reason to.
