stephen.holdcroft
posted on 15/4/09 at 01:34 PM |
zzr trouble
Just got my zzr1100 finally fitted with wiring and prop fitted but now can not get it to start. Have sparks at the plugs, fuel at carbs and it turns
over. If you push trottle while cranking it over engine noise changes ant turns over slower.
Any on have any clues, as been running before but as stood for a couple of months.![](/images//smilies/mad.gif)
mackei23b
posted on 15/4/09 at 01:58 PM |
My ZX9R I had the same simptoms of spark, petrol and no signs of life on its first start.
I cleaned the plugs and used full choke and it burst into life.
Also try some WD40 / carb cleaner direct down the trumpets to see if you can get an initial start?
stephen.holdcroft
posted on 15/4/09 at 02:45 PM |
Thanks will give the w40 a try, thanks
posted on 15/4/09 at 03:10 PM |
^^^ or tip a few teaspoons of petrol onto the air filters - same sort of ting if you don't have eezey start.
A1
posted on 15/4/09 at 04:36 PM |
eezy start, got mine going after days of nothing![](/images//smilies/sad.gif)
matt_gsxr
posted on 15/4/09 at 08:23 PM |
Make sure your battery is nice and juicy. Once the volts drop (with cranking) the spark that looks nice in the open air can disappear, especially
once the plugs get a bit wet.
A car battery is good for this.
Easy-start is also the business.
Finally, now your plugs are a bit fouled, I would pop them out, give them a scrub (brass spark-plug brush, not the steel one I used!!!!) and then heat
the ends on a gas ring, just to burn off anything unpleasant. If you pop them back in warm then any flooding problems will also be lessened.
Matt
p.s. its going to sound so good when it goes.
