Jasper
posted on 21/4/09 at 08:11 AM |
Help fitting IDE HDD
I want to fit a second IDE drive to one of my home PC's. It's an old Dell machine and has only got a single HDD connector on the ribbon
cable. Can I just fit a ribbon cable with two connectors on? If so, anybody got an old one lying around they don't need?
madmandegge
posted on 21/4/09 at 08:24 AM |
Should just be that simple yes! One will have to be master, one will need to be slave, this is controlled by the jumpers on the back of the HDD.
I'll have a look, but am 99% certain I don't have a spare anymore! Everything's gone SATA
geoff shep
posted on 21/4/09 at 08:34 AM |
Is there another IDE channel on the motherboard that connects to a CD or DVD drive - does that have another connector?
jlparsons
posted on 21/4/09 at 09:42 AM |
Some motherboards can be a bit funny and not autodetect hard disks, in which case you'll need to enter the information on the sticker on top of
the drive into your PC's bios. Best thing is to take a picture of the sticker with your digital camera/phone before you install it, that way
you won't end up ripping the bugger back out to check details to set it up.
95% chance it'll just work though.
Jasper
posted on 21/4/09 at 09:52 AM |
Yup - tried that - didn't recognise the drive - though I'd better put it on the same cable as the other drive.
And I'm ok with the master/slave thing. I've fitted plenty of HDD before, but never to a machine that didn't have a connector ready
for it.
ReMan
posted on 21/4/09 at 10:18 AM |
If no-one gets in quicker I'll have one at home that I can put in the post tonight.
It should work OK
Jasper
posted on 21/4/09 at 10:34 AM |
Thanks chaps - just got one from Ebay for £1.50 delivered!
