Author: Subject: speedo sensor pick up
Stuart_B
posted on 22/5/09 at 12:41 PM Reply With Quote
hi all, can i mount a speedo sensor on the one of the front wheels?
it is undriven wheel, but i have passed sva all ready so now worries about that?
but i was wondering promblems off when turning one wheel soins quicker than the other, so it would make no differnace if i put it on the rear wheel than the front?
your throught please?
thanks
stuart
prawnabie
posted on 22/5/09 at 12:49 PM Reply With Quote
As long as you have passed sva/iva and it reads more or less the right speed then I can't see a problem. Alot of modern cars read the speed off one of the wheel bearings anyway.
Shaun
posted on 22/5/09 at 02:11 PM Reply With Quote
Fundamentally not a major problem post SVA!!! One advantage of having the speedo on a non-driven wheel is you won't get MPH blips due to wheel spin....
Stuart_B
posted on 22/5/09 at 03:14 PM Reply With Quote
thanks i will keep to the orginal plan then.
stuart
Xtreme Kermit
posted on 22/5/09 at 05:51 PM Reply With Quote
I took a different approach and bought a converter from the type 9 speedo output to a threaded output and mounted the transducer on that.
No worries of magnets flying off...
prawnabie
posted on 22/5/09 at 06:39 PM Reply With Quote
If you are running cortina uprights, the bolt heads that hold the disc to the hub pass a "hole" in the upright. Im sure you can get a sensor that reads "metal" instead or "magnet" and do it that way?
jeffw
posted on 22/5/09 at 09:47 PM Reply With Quote
I tried to moment a magnet on the front wheel and the pickup on the upright. Worked fine until you turned the wheel and the speedo stopped working. Ended up mounting it on the rear axle/wheel;
Stuart_B
posted on 23/5/09 at 07:55 AM Reply With Quote
ah, i just worked out my speedo as well will be ok will doing straight, but wont work while truning.lol
change of plan time.lol
stuart
prawnabie
posted on 23/5/09 at 11:40 AM Reply With Quote
I might be dumb here, but why wouldn't it work?
Surley the upright and the disc/hub are the same distance away regardless of whether you are turning or not?
There may be a bit of flex, but not enough to cause problems else we would be changing wheel bearings every month lol.
Shaun
Stuart_B
posted on 23/5/09 at 03:39 PM Reply With Quote
the way i was going to make the bracket was, to be held on the wishbone bolt which hold teh bottom balljoint on, so that part does not move the sensor would not trun, so i might look at mounting to the hub or teh rear drums some how.
i am running sierra uprights.
thanks
stuart
triumphdave
posted on 23/5/09 at 06:37 PM Reply With Quote
This is what I have done
