mcerd1
posted on 2/7/09 at 09:08 PM |
windows XP (net framework) - help!
I can't seam to get anything newer than net framework 1.1 sp1 to install on my PC
I just get loads of errors like this:
and microsofts website is about as useful as a chocolate fire guard
any ideas ?
RichardK
posted on 2/7/09 at 09:12 PM |
Is it a work pc? I suspect its a rights issue, can it be run as administrator, you also need to ensure windows installer 3.1 is already on your
machine.
Rich
Gallery updated 11/01/2011
flak monkey
posted on 2/7/09 at 09:16 PM |
As Rich says. Either that or something else is running preventing access to that file.
Or try installing in safe mode, sometimes works.
Sera
http://www.motosera.com
blakep82
posted on 2/7/09 at 09:18 PM |
jesus! i opened this thread, saw that message, cacked myself, then cacked myself again that that it wouldn't go away when i clicked it
________________________
mcerd1
posted on 2/7/09 at 09:19 PM |
its my home PC and I've got an admin account, and its already got installer 3.1
RichardK
posted on 2/7/09 at 09:21 PM |
Ok mate try this from a command prompt
cd \windows
cacls assembly /G SYSTEM:F
then press the enter key to run the command.
then hit the retry button on the installer error page.
cheers
Rich
[Edited on 2/7/09 by RichardK]
tegwin
posted on 2/7/09 at 09:25 PM |
I had a nightmare getting it to install in the past...
Do you have the latest service pack with the latest patches?
In the end I just rebuilt the machine...... Im sure there was some process running that shouldnt have been....
www.verticalhorizonsmedia.tv
Agriv8
posted on 2/7/09 at 09:30 PM |
try killing all but essential software
or set up another account grant it admin and try install using that account.
or try a newer ver of .net ( as they are ussually backward compatable ) sure I put 3.5 on a win2k8 server the other day
posted on 2/7/09 at 10:13 PM |
http://social.msdn.microsoft.com/Forums/en-US/netfxsetup/thread/8b122e4d-fc33-49a7-9f81-49016c734c4a
mcerd1
posted on 2/7/09 at 11:45 PM |
cd windows
cheers
Rich
thats not working
and when I go to rename the 'assembly' folder it says access denied
and I've tried it all again logged on as 'administrator' and its still the same.......
mad4x4
posted on 3/7/09 at 06:47 AM |
It's a rights issue,
Folder assembly is not assessible by the admin or the system account with enough authority to change the rights on it, effectively locking you out
of the folder. You need to some how find a way to "break" into the folder and change the rights so it can be be granted full control.
one option would be convert the File system to FAT32 this would remove the NTFS rights. Don;t know there may also be a ntfs rights craking tool
utilility thing that you could use......
Scot's do it better in Kilts.
RichardK
posted on 3/7/09 at 07:32 AM |
Try doing those moves in safe mode,(pressing f8 during boot),other than that it seems like the acl (access control list) permissions are screwed for
that folder.Can't help further as it gets a bit tricky to advise by messaging. Cheers Rich
mcerd1
posted on 3/7/09 at 07:43 AM |
the disk is a raid 0 array if that makes any difference (nvidia controller)
but I think I might have bigger problems
it hangs when booting safe mode, I've started getting 'can't read system32 folder' error again and scan disk found a whole
load of errors in the index's
looks like I'm going to give up and get the new HDD a bit sooner than I wanted to.....
RichardK
posted on 3/7/09 at 08:08 AM |
Mmm, sounds like you disk is at end of life and is corrupting the file system, hence your troubles, get your data off asap onto a stick or drive.
Rich
mcerd1
posted on 3/7/09 at 08:59 PM |
1 new disk and 24 hours later (about 6 hour just updating from SP1 )
and it seems to work
what would you recommend to test the old disks ? (now that they are redundant)
[Edited on 3/7/09 by mcerd1]
