Stott
| posted on 19/7/09 at 06:02 PM |
Fujitsu Siemens Laptop Problem
Hi all, I've got a fujitsu siemens esprimo laptop C45 V5545 is what it says on the bottom.
The switch that operates when the screen is open/shut is playing up, I have to flick it with a pen top to get the screen to come on and sometimes it
doesn't recognise when it's shut and the screen stays on, it gets all hot and bothered then as it's downloading updates and the like
when it's closed.
I've searched the net and can't find any specific info and unfortunately it's just out of warranty, does none have any clues as to
where/how to get a spare part or how to fix it?
Cheers, Stott
blakep82
| posted on 19/7/09 at 06:19 PM |
mine does that sometimes (not a siemens though) have a nasty feeling if the switch has gone, it'll involve some soldering on a a very expensive
circuit board.
on the key board though, there should be a button you can press which put the laptop in the same position as when you close the top down (depends how
you have yours set up)
on mine its fn + F4
________________________
RichardK
| posted on 19/7/09 at 07:39 PM |
You can tell windows to ignore whether the lid is shut or open, control panel, power option and its in there.
Rich
Gallery updated 11/01/2011
Stott
| posted on 19/7/09 at 08:40 PM |
as a follow up I forgot: it also says no battery detected, all the time and as soon as I unplug it, it'll switch off, ??????
RichardK
| posted on 19/7/09 at 08:51 PM |
You'll need to have a gamble and try another battery to find out if its the battery (probably) or the charging circuit on the main board.
Rich
morcus
| posted on 19/7/09 at 10:15 PM |
I wouldn't recomend Fujitsu siemens laptops to anyone, I've had two and my brothers had one (That went back 3 times) and they've
never been very good or lasted long without falling apart.
My fully charged light hasn't come on since the last time I unplugged the charger (2 weeks ago) and the keyboard is pretty much dead (The
numbers work and I think e h and O but thats about it).
