Author: Subject: 2.5 in SATA drive enclosue (caddy?)
posted on 22/7/09 at 06:57 AM Reply With Quote
when I replace by lappy's 2.5 inch SATA drive, I'll either sell it - probably won't get much for it - or more likely use it as portable back up.
For the latter purpose, I would need an portable SATA Hard Drive Enclosure USB 2.0 type of thing.
So what does the collective locostbuilder's brain recommend?
Ideally it must be light, reasonably rugged so made of metal, e.g. aluminium and cheap.
One candiatie is this:
Oh, and I'll need some drive cloning software (there is meant to be one on Western Digital's website but I've yet to look hard) so again recommendations and pointers.
ta.
mad4x4
posted on 22/7/09 at 07:01 AM Reply With Quote
I got a green mesh type one from EBAY only cost about 6 quid and in anly slightly bigger than the drive. No probs so far.
Dirve has even survived a roymail trip from glasgow in said caddy.
Scot's do it better in Kilts.
yellow melos
posted on 22/7/09 at 07:06 AM Reply With Quote
I got mine from E-bay for about £3, but it did not have any sofware... but then none of them will that as you are only buying the case. the case was blue alluminium and because it was 2.5inch drive it was powered from the USB bus.
also most cloning software require that the destination drive be the same size as the original.
better using an incremental backup type of program like backup XML or somthing like that.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 22/7/09 at 07:13 AM Reply With Quote
got mine from eBay, nice and cheap about £4, it was a nice black metal.
posted on 22/7/09 at 07:14 AM Reply With Quote
ahh, that is interesting. the bit I saw about Western Digital cloning software was someone fitting larger capacity drive, same make and model range - this obviously has impact on which HD I buy, WD or seagate.
iank
posted on 22/7/09 at 08:50 AM Reply With Quote
Got mine from callright
http://www.callright.co.uk/
http://callright.x2tek.co.uk/dept/Hard-Disk-Enclosures_74.html
They don't need software (on anything post win95), to the computer they are just an enormous USB flash key.
Anonymous
geoff shep
posted on 22/7/09 at 02:41 PM Reply With Quote
Do your research - a portable drive for a laptop is most convenient if it will work from the laptop alone (for power) and not need, at worst, a mains lead and at least a double usb lead (to supply enough power from 2 usb ports).
I have done exactly what you plan to do on 2 separate laptops. I used this case from ebuyer which is plastic but rugged and runs off a single cable.
Use something like Easeus to copy your old disk to the new one which you put temporarily in the new case. Then put the new one in the laptop and check that it works - it should boot up like it's never been changed. Once you are happy that everything works, pop the old disk in the case, format it and you have a portable external HDD. Simplesk.
(Make sure you always have a backup until you are sure it's all working)
posted on 22/7/09 at 03:19 PM Reply With Quote
you mena no need to install drivers?
but the software I refer to is to copy contents of hard disc in lappy to the one in USB so that that one becomes the boot disc; (Seagate Discwizard. )
next remove disc from USB enclosure and swap it with the one the lappy and hopefully it will boot and run as before.
geoff shep
posted on 22/7/09 at 04:43 PM Reply With Quote
The software I mentioned will clone your old disk to a new one - irrespective of manufacturer.
iank
posted on 22/7/09 at 06:13 PM Reply With Quote
Yes, no driver required to do that, just the software to write the disc partitions and set the boot flag in the right place. Plenty of ways of doing that.
http://en.wikipedia.org/wiki/List_of_disk_cloning_software
[Edited on 22/7/09 by iank]
Anonymous
