posted on 25/7/09 at 06:36 AM |
mkaing USB printer wireless?
is there such a thing that can be plugged into USB printer to make it WiFi wireless?
i.e. so I can print from lappy without cables.
Ben_Copeland
| posted on 25/7/09 at 06:42 AM |
AFAIK You can get Wireless Printer Servers ....
http://www.netgear.co.uk/wireless_print_server_wgps606.php
Just the first one that came up
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
| posted on 25/7/09 at 06:56 AM |
ta ... it is really knowing what this gadget is called, now I know.
oh, it also needs to be powered by t he printer from its USB as opposed to have its own power supply and as small as possilble.
Ben_Copeland
| posted on 25/7/09 at 07:05 AM |
Trying to be difficult will get you nowhere
http://www.google.co.uk/products/cata
log?hl=en&q=wireless+printer+server&cid=14691815665144670238#p
Or in this case... somewhere
[Edited on 25/7/09 by Ben_Copeland]
Ben
Roadster
blakep82
| posted on 25/7/09 at 08:16 AM |
have you already got a desktop PC wired into a your router? it might be possible to do it without buying anything extra....
i can't remember how i did it exactly, but i've got a wireless router, and a desktop PC wired right into that. the desktop has the printer
plugged into it though the usual printer port in the back. i've got it set so i can print from my laptop, through the desktop, and into the
printer.
of course it mean the desktop has to be on all the time, but it is for email anyway
________________________
mookaloid
| posted on 25/7/09 at 10:48 AM |
Some routers have a usb port which can be used to run a printer - BT home hubs are an example I believe
blakep82
| posted on 25/7/09 at 11:31 AM |
the home hub does have usb ports on it, didn't know you could put a printer straight to it though
mookaloid
| posted on 25/7/09 at 11:49 AM |
have a google for 'home hub printer'
I have an orange livebox which apparently also does it .
ChrisW
| posted on 25/7/09 at 11:54 AM |
Most of the Draytek routers have the USB function on them.
Excellent bits of kit, used loads of them over the years. Currently on a 2820, which does the USB printer thing and ADSL2+.
Oh, if it's an HP printer, and has a parallel (old style) printer port, eBay up a 'Jet Direct'. Nobody uses them any more as they
go cheap. But, they're not wireless, so you'll need to run a cable to your router so that your laptop can see it via the wifi.
Chris
Big Stu
| posted on 25/7/09 at 12:34 PM |
BT home hub
The latest BT home hub (The black curved one) can be used for remote printing and also file sharing, IE plug in an exteranl hard drive and any comp on
your network can access it. Used it for both quite easy to setup
