kipper
| posted on 27/9/09 at 05:39 PM |
Cant log in
I am having probs logging in.
Prompt at the top rh side says not logged in, press log in,type user name and password and nothing changes??????????
I Know it will be me doing sumat wrong ,but what
Kipper..........aka Denis.
speedyxjs
| posted on 27/9/09 at 05:42 PM |
I had that. Switched to firefox and have had no probs since.
Paul (Notts)
| posted on 27/9/09 at 07:19 PM |
Check the date is correct on your computer...
kipper
| posted on 27/9/09 at 11:34 PM |
I checked the date and it was wrong.
I put it right but still can't log on
Fozzie
| posted on 28/9/09 at 08:38 AM |
Bit befuddled here....if you can't log in, how come you are posting as 'kipper' ?
Fozzie
kipper
| posted on 28/9/09 at 12:04 PM |
sorry fozzie, I can't answer that.
I am using the works puter right now but at home it says not logged in,I press the login fingy at the top rh, go through the log in procedure,
username, password etc,
nothing changes.
on the works puter I have logged in as Kipper in the top rh?????????
Where did that go?
Fozzie
| posted on 28/9/09 at 12:14 PM |
Ah..ok..sounds more like that you have a browser issue on your home 'puter then!
If you aren't using FireFox, consider downloading it...but.... make sure it is the 'en-gb' version.
HTH Fozzie
kipper
| posted on 28/9/09 at 02:22 PM |
Ok I will try that , wish me luck
Denis.
Where did that go?
Fozzie
| posted on 28/9/09 at 02:27 PM |
Denis.
Good Luck Denis.....
Fozzie
kipper
| posted on 28/9/09 at 10:45 PM |
cant log in
Hi .I downloaded firefox and things are back to normality now, Thanks every one.
Kipper.............AKA Denis.
Where did that go?
Fozzie
| posted on 28/9/09 at 11:15 PM |
Hi .I downloaded firefox and things are back to normality now............
Excellent news!
Fozzie
