Jasper
| posted on 5/10/09 at 03:41 PM |
What hard drive do I need
I built my own PC a couple of years ago, I've got 2 x 350GB internal SATA HDD.
I want to add another big drive As they're permanently full, but not sure which speed to go for:
http://www.scan.co.uk/Index.aspx?NT=1-0-18-432-0
Can anybody recommend one?
blakep82
| posted on 5/10/09 at 04:02 PM |
if you don't need internal, there seems to be plenty of external 1tb drives for about £60
________________________
Agriv8
| posted on 5/10/09 at 04:49 PM |
personally if you have 700 gb  of data I would be asking the following questions
Do you need all the data you already have ?
Archive some data off ( ZIPed to DVD )
can you afford to loose it ?
700 gb of data is a lot to loose
is it backed up ?
Id say you were better of with some NAS storage. That will be indipendant of OS upgrades as your currnet hardware is 2 years old .
Sorry this was only going to be a one live answer got a bit carried away
regards
Agriv8
westf27
| posted on 5/10/09 at 04:57 PM |
so he collects a lot of pictures
555
blakep82
| posted on 5/10/09 at 05:31 PM |
pr0n
Staple balls
| posted on 5/10/09 at 05:54 PM |
http://www.scan.co.uk/Index.aspx?NT=1-0-18-432-0 />
Generally if it's just a storage drive, you'll do well with one of the newer 5200 rpm green drives, they're not fast, but
they're cheap and quiet.
Otherwise, I'd buy a nice fast 7200rpm drive and put up with the noise
My personal preference is WD and samsung drives, I've not had much trouble either.
I'd buy either of these, depending on what I said up there:
Slow or
Fast
| posted on 5/10/09 at 07:22 PM |
Go for a big external NAS drive
You can access most NAS drives by wired network or USB as already said they are OS independent.
Jasper
| posted on 5/10/09 at 08:32 PM |
Everything is backed up in two places - but I've got a lot of HD movies and they really take up some room (4-10GB each...)
Are the NAS drives as fast as an internal SATA one though?
I've got two Seagate Barraccuda ones in there now and they've been perfect, probably go with another one then, £63 ain't bad!
[Edited on 5/10/09 by Jasper]
