Author: Subject: PC wont turn on.
Jasper
posted on 30/10/09 at 09:37 AM Reply With Quote
PC wont turn on.
So I came home last night, pushed the button on the front of my PC and nothing.
I've checked the fuse, and checked there's actually power coming to the PC power supply, all ok.
So what's the order I should be checking things inside the box. Presumeably it's looking like a power supply problem. The PC is home built using good parts, the powers supply itself is a Tagan one.
[Edited on 30/10/09 by Jasper]
l0rd
posted on 30/10/09 at 09:39 AM Reply With Quote
check for power socket
RichieHall
Does the fan wind up? Motherboard beep? Any lights, smells or other noises?
Rust is lighter than Carbon Fibre!
dinosaurjuice
posted on 30/10/09 at 09:41 AM Reply With Quote
my tagan power supply stopped working last month
spent hours testing it and came to the conclusion that it was scrap.
Benzine
posted on 30/10/09 at 09:45 AM Reply With Quote
They do go sometimes. I had a decent corsair psu that just stopped working Sent it back and got a replacement pretty quickly though.
thunderace
posted on 30/10/09 at 09:47 AM Reply With Quote
i have the same problem with the mrs
(,she didnt like me in the uniform) .
[Edited on 30/10/09 by thunderace]
thunderace
posted on 30/10/09 at 09:50 AM Reply With Quote
bet its the mains tranformer in the pc.
easy to test and swap .
will look like this in most pc
http://cgi.ebay.co.uk/TOPOWER-300-Watt-Switching-Power-Supply_W0QQitemZ260484392477QQcmdZViewItemQQptZUK_Computing_PowerSupplies_EH?hash=item3ca614661 d
Jasper
posted on 30/10/09 at 09:53 AM Reply With Quote
No, absolutely nothing at all....
Ahhh - I think I've found the problem, the small cable that goes to the front panel switch is not plugged in to anything, it's a tiny flat two pin connector with Power SW written on it, but I'm bugger if I can see where it plugs back in to. Presumeably it's on the motherboard?
l0rd
posted on 30/10/09 at 10:23 AM Reply With Quote
Spot on.
austin man
posted on 30/10/09 at 10:38 AM Reply With Quote
worrying that a wire has just fallen off from the inside of your pc, I would be ouutside now checking the bolts on my suspension to make sure i tightened them up correctly LOL
Jasper
posted on 30/10/09 at 11:00 AM Reply With Quote
OK, so I've plugged the little power switch lead back in to the motherboard, and still nothing, how do I go about checking the power supply? I don't have a spare one I can swap over.
Should there be some voltage at the pin outs on the motherboard for the power switch? I've got a volt meter here.
I've put a volt meter (on 10v DC) on the main thick bank of leads going to the motherboard from the power supply, nothing.
l0rd
posted on 30/10/09 at 11:09 AM Reply With Quote
http://modtown.co.uk/mt/article2.php?id=psumod
Jasper
posted on 30/10/09 at 11:33 AM Reply With Quote
Thanks, did that, still nothing from the PSU at all, so presumably it's junk then, and get a new one....
Just checked with Scan, Tagan power supplies are warranted for 3 years, so I'll get a new one from them.
Thanks chaps - as usual
l0rd
posted on 30/10/09 at 11:57 AM Reply With Quote
Just pray it didn't take anything else with it when it died
mookaloid
posted on 30/10/09 at 12:21 PM Reply With Quote
Last time I had a PSU go it took the MB with it
mad4x4
posted on 30/10/09 at 12:44 PM Reply With Quote
You post here made it so I would guess that the PC is working fine....... Check the monitor connection or switch it must still be off so you cannot see what you are typing because we can see it.
Scot's do it better in Kilts.
Jasper
posted on 30/10/09 at 12:57 PM Reply With Quote
I'm on my work PC, it's my home one that's buggered.... hope the MB is ok
mangogrooveworkshop
posted on 30/10/09 at 01:09 PM Reply With Quote
He might of done that if he still had a car to sit in.........jaspers car had a wee problem a few weeks back. Search posts for the clue
James
posted on 30/10/09 at 02:26 PM Reply With Quote
Ask Jasper about the wheel nut 'problem' he had a few years ago just before getting on the track at Brands!
James
Jasper
posted on 30/10/09 at 03:23 PM Reply With Quote
Oh yes, forgot about that Pulled into the garage just before Brands to fill up - had driven there from Brighton, and found ALL my wheel nuts loose where I'd had the wheels off to check the pads the day before
Anyway - check this out. My Tagan PSU comes with a 3 yr warranty. Guess when I ordered it from Scan? 30/10/2006, yeah - really .... BUT the warranty is taken from the day it arrived and I signed for it, 3/11/2006, so it's still in warranty, JUST!!! Have to say the guys at Scan have been really good about it.
Ninehigh
posted on 7/11/09 at 07:32 PM Reply With Quote
Sale of goods act, how long should it last?
Tbh warranty doesn't mean squat with that law around
