Poll: ACER NETBOOK CONVERSION [View Results]
Tried and tested XP
Do a dual boot xp ubantu
or virtual pc
Author: Subject: ACER NETBOOK CONVERSION
mangogrooveworkshop
posted on 12/11/09 at 10:01 AM Reply With Quote
The problem is my acers netbook A101 Aspire running a funky flavour of linux that wont talk to my nokia 5800 as a modem.
We have done work arounds but they arnt that stable in wine.
I hate windys but will run it in order to talk to the phone....
What flavour should we try of windows or other.
AdamR
posted on 12/11/09 at 10:06 AM Reply With Quote
I'm not what you'd call a linux expert, but can you not run the phone software under wine?
posted on 12/11/09 at 10:23 AM Reply With Quote
I run dual-boot at home. Works very well and if you edit the config files (so that the time-out on the OS select is 5 seconds rather than 30) it doesn't slow down much a "normal" boot.
chrsgrain
posted on 12/11/09 at 11:04 AM Reply With Quote
I'd buy a different phone.....
CHris
Davey D
posted on 12/11/09 at 12:59 PM Reply With Quote
Id just stick with ubuntu on a netbook, and try getting the phone working.
posted on 14/11/09 at 05:58 PM Reply With Quote
Do you mean the Acer One? (not heard of the A101). If so do you have the hard drive version?
mangogrooveworkshop
posted on 14/11/09 at 06:11 PM Reply With Quote
yes its the hard drive one
McLannahan
posted on 14/11/09 at 06:22 PM Reply With Quote
I have the SSD version and I stuck XP on it. Works a treat - fast too, much better than I thought it would be.
Installed it from a bootable USB stick I created with the whole XP install on.
posted on 14/11/09 at 06:41 PM Reply With Quote
Simple if you have enough memory use Sun VirtualBox to run Windows as a virtual machine, note it has to be the Sun version not Open Source VirtualBox to run USB devices.
The Sun version is free for personal or evaluation use.
I use this method to run all sorts of Windows USB car diagnostic interfaces on Linux PCs.
http://www.sun.com/software/products/virtualbox/
posted on 14/11/09 at 06:50 PM Reply With Quote
Unless mango's upgraded it the Aspire One comes with 512MB memory...is running the above going to possible without the whole thing grinding to a halt?
