MakeEverything
posted on 30/12/09 at 10:26 PM |
Turbocad .......
Anyone got an activation code?
Kindest Regards,
Richard.
MakeEverything
posted on 30/12/09 at 11:04 PM |
Also,
When i put this into 3D in TurboCAD 16, i cant get the inner holes to "Cut out" of the larger square plate. Anyone know how to do this?
  Exhaust Flange CAD
Kindest Regards,
Richard.
ReMan
posted on 31/12/09 at 12:58 AM |
Google seems too ?
minitici
posted on 31/12/09 at 09:35 AM |
I use the mac version of TurboCad.
To create the shape with the cutouts, I would create a smart polygon rectangle then set out the centre circle and the 4 smaller circles.
Switch to isometric view then select the extrude to create a solid tool.
Hold the shift key down and select the polygon and the 5 circles, release the shift key and move the cursor to a end or centre point, click and drag
vertically along the z axis (if you were originally using top view).
You can edit the length of the extrusion by editing the distance in the information bar.
You should now have a solid with all the 5 cutouts
Ben_Copeland
posted on 31/12/09 at 09:46 AM |
Dont go googling "activation codes"... you'll get all maner of nasties on your computer from the websites !! (if you enter them)
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
