Author: Subject: PC blowing fuse?
posted on 13/1/10 at 07:43 PM Reply With Quote
PC blowing fuse?
I installed a new home PC just before Christmas and the 5A fuse in the power lead plug has blown twice now. It's happened when I've turned on the PC. I'm wondering if it's the PC that's at fault or if it's possibly due to the surge protected extension lead I have the PC plugged into.
Any ideas?
Phil
mangogrooveworkshop
posted on 13/1/10 at 08:16 PM Reply With Quote
You may need to put a slow blow fuse rated at five amps.
the startup surge may be just enough to take the fuse out.
locostbuyer83
posted on 13/1/10 at 09:02 PM Reply With Quote
try it without the surge protector and see if it works.
could be the power supply if it still does it.
posted on 7/7/10 at 04:38 PM Reply With Quote
Anybody know where I can buy a standard size (1" x 0.25" 5A slow blow fuse from? I've tried e-bay but the ones they sell are 20mm x 5mm.
Phil
Ninehigh
posted on 7/7/10 at 05:22 PM Reply With Quote
You could try a 13A one, if it blows that you got problems
flak monkey
posted on 7/7/10 at 05:51 PM Reply With Quote
My PC needs a 7A fuse...
Depends on your power supply requirement - you do get quite a surge at start up, but should be ok after that.
Sera
http://www.motosera.com
