Author: Subject: Increasing hard drive size
speedyxjs
posted on 15/1/10 at 11:40 AM Reply With Quote
I brought a new 160gb hard drive for my laptop and installed windows vista (wouldnt let me install XP).
When it asked for the install directory, i made a 40gb partition on the hard drive but now it only shows the 40gb partition and no the other 120gb
Do i need to reinstall windows to correct this or is there another way?
Liam
posted on 15/1/10 at 11:46 AM Reply With Quote
You've probably got to go into disk management (I'm talking XP here but Vista probably has similar in control panel/administrative tools somewhere) and actually create/format your second partition, before it will be recognised. During the install process you created the 40gb partition for windows, but it wouldn't automatically have sorted out the second partition, I dont think.
Liam
flak monkey
posted on 15/1/10 at 11:50 AM Reply With Quote
What Liam said, its not picking it up as the other partition isnt formatted.
Vista has disk manager too, just use that to format the rest of the disc, then you will be able to use it.
Sera
http://www.motosera.com
m8kwr
posted on 15/1/10 at 11:52 AM Reply With Quote
use compmgmt.msc to access computer management. This works on XP, i don't have a vista machine to try it on.
There should be a Disk Management node, click that
At the bottom you should see your 120gb that you have no assigned to a drive letter, or formatted etc.
I think it is right click, Mark Partion as Active, it may ask you to format etc from there, but without this on my machine i am unsure of the screen prompt.
HTH
speedyxjs
posted on 15/1/10 at 12:10 PM Reply With Quote
Brilliant, cheers guys. All sorted now
Mr Whippy
posted on 15/1/10 at 12:26 PM Reply With Quote
just changed from Vista to XP on my new laptop, thank god
The CD Automatically removed Vista (and all my drivers, must remember to back them up next time)
The machines totally transformed and working fantastic runs all my programs and seems much more powerful running vids and graphics. Awful Vista garbage
next to do is the GFs laptop
[Edited on 15/1/10 by Mr Whippy]
speedyxjs
posted on 15/1/10 at 12:29 PM Reply With Quote
When i put the xp disk in, it doesn't detect my hard drive and so wont allow me to install it. If i plug in an external har drive, it will detect that but wont install on that either.
Whats your secret whippy?
Mr Whippy
posted on 15/1/10 at 12:41 PM Reply With Quote
You got a genuine copy of XP then? When I did mine it shows the drives and then asks you to remove the partitions then it installs. There was a funny way to get the installation process going.
Had to boot it up the computer, once at the desk top screen, insert the CD, switch off, restart I think it was. I bough my disk of the web for £30.
I hadn’t a clue what I was doing and just followed the instructions word for word. I could photograph and send you then if you have none. Really am glad I got rid of vista, it was hellish and wouldn’t run any of my older programs.
Just mind to make a backup disk with the drivers unlike me, tbh I'm not even sure how to do that. Got them all of the web from the HP website and other sites, thanks to good advice of guys on here
posted on 15/1/10 at 12:44 PM Reply With Quote
I've had Vista on here since 2008 and apart from the driver for a scanner not being available it's been no trouble at all. I'm not a big fan of XP or Vista, our old computer still runs fine on 2000 pro and you don't have to ask it if you can do something or activate it so they know where you are. We'll try Windows 7 on the next one I build. I formatted a laptop and installed XP for a friend a few weeks ago but it was mostly automatic, does your hard drive show up in bios ?(I assume it does if the computer is working) and have you tried formatting the drive then installing xp which is the only way to go really. As above make sure you have the motherboard drivers for xp or you will be stuffed.
Mr Whippy
posted on 15/1/10 at 12:46 PM Reply With Quote
^ my XP disk formated the hard drive as part of the installation process
speedyxjs
posted on 15/1/10 at 12:48 PM Reply With Quote
Yeah, its a genuine copy.
Il wait till the new partition has finished formatting and il give it another shot.
Mr Whippy
posted on 15/1/10 at 12:52 PM Reply With Quote
have you got instructions?
speedyxjs
posted on 15/1/10 at 01:09 PM Reply With Quote
Yes i have the instructions.
I just tried it again (after formatting) and its just come up with the same message saying it cannot detect a hard drive.
AndyGT
posted on 15/1/10 at 01:10 PM Reply With Quote
What format have you used?
NTFS is the one that XP usually sees best.
nothing is impossible
everything is possible
speedyxjs
posted on 15/1/10 at 01:12 PM Reply With Quote
yeah, its NTFS
mcerd1
posted on 15/1/10 at 01:13 PM Reply With Quote
what kind of laptops are we talking about here ?
I've had win 7 (64 bit) for a few months now on my new desktop (i7)
and I quite like it so far, the only issues I've had are trying to run older stuff on it and even then 70% of that seems to work just using the compatability modes
(I never liked vista though)
but still keep and XP machine for the old programs (and xp on the laptop)
posted on 15/1/10 at 01:54 PM Reply With Quote
Very likely because your notebook has a SATA drive and original XP disks don't have support for this (which service pack is on your install disk?).
If you have a floppy drive (unlikely on a notebook) the XP installer allows you to load SATA drivers at the beginning of the installation. Otherwise you need to get the appropriate drivers and "slipstream" them into the XP installation and burn a new install disk. It's not difficult to do
robocog
posted on 15/1/10 at 06:05 PM Reply With Quote
worth having a look in the BIOS to see if you can change the SATA to "legacy IDE" or similar wording
Regards
Rob
