theconrodkid
| posted on 24/1/10 at 06:17 PM |
doubling up
if a compo is hard wired to the interweb via the BT phone line,can you use a phone doubler and use 2 compo,s on the same line?
who cares who wins
pass the pork pies
tegwin
| posted on 24/1/10 at 06:21 PM |
Are you talking about a dialup connection or a broadband enabled phoneline?
If its dialup, then NO... if its a broadband connection, then possibly.. assuming you have multiple channels enabled on the line....
The normal way of achieving this is to network both computers together so they share a single internet connection... Unless for some reason you wanted
multiple IPs
www.verticalhorizonsmedia.tv
theconrodkid
| posted on 24/1/10 at 06:26 PM |
sounds complicated,ill tell her not to bother and get a wireless router.cheers for yr reply
who cares who wins
pass the pork pies
Daddylonglegs
| posted on 24/1/10 at 06:33 PM |
Wireless router everytime. Cheap as chips now and dead easy to setup
tomprescott
| posted on 24/1/10 at 06:54 PM |
If your on broadband then your current router may be capable of a wired connection already? The wireless router that came with my contract also had
four wired connections from the back of it!
bigfoot4616
| posted on 24/1/10 at 06:57 PM |
wired connections are much more reliable than wireless
splitrivet
| posted on 24/1/10 at 07:42 PM |
If your using a broadband modem change it out for a router then use a couple of patch leads to hardwire both into the router.
Bob
