austin man
posted on 27/1/10 at 06:12 PM |
Laptop power supply
Can anyone advise on the following, have a damaged power supply for a laptop rated at 19.5v 4.7a and also have a good used power supply rated at
19.5v 6.15a
can I use the second one on the laptop will there be any damage potential to the laptop?
tegwin
posted on 27/1/10 at 06:46 PM |
The ampage is the maximum potential supply the transformer can give..... so providing the voltages are the same.... it will work just fine! its not
a toshiba power supply thats broken is it?..
www.verticalhorizonsmedia.tv
r1_pete
posted on 27/1/10 at 06:48 PM |
Yes the higher current rated power supply will be fine.
Using a supply rated less would cause the ps to overheat, and fail.
austin man
nope a sony one where a rabbit has chewed the wires and its shorted out , I have a couple of spare toshiba satelite ones spare as well
