Steve Hignett
posted on 30/1/10 at 05:29 PM |
Solidworks Help Wanted please... (AGAIN!)
Hi All,
I've had another stab at drawing something in Solidworks and don't know whether I've done it right!
I wanted to draw the part in the last photograph with a 10mm Tapped hole, so I at first drew it with an 8.5mm hole, then tried to find the threaded
feature etc. After searching google I tried what I thought was the tap funtion in the hole wizard and thought I'd cracked it.
But it is not showing it drawn as a tapped/threaded hole. Is this how it should look, or should it show the threaded portion as threaded in the
dwg?
ps - It's just the last dwg that I thought I'd done it correctly on...
  SW
  SW
  SW
  SW
  SW
  SW
  SW
  SW
dinosaurjuice
posted on 30/1/10 at 05:34 PM |
remove the hole and then use the hole wizard
edit to add: make sure the view is up-to-date by clicking the traffic lights.
[Edited on 30/1/10 by dinosaurjuice]
atm92484
posted on 30/1/10 at 05:54 PM |
Select the plane you want to make the hole in, go to Insert > Features > Hole > Wizard. Enter your parameters in there and it will make your
threaded hole. At the end of the wizard, select a point to locate the center of the hole.
I normally just make the hole size for the required tap and call out the threading on the final drawing.
[Edited on 30/1/10 by atm92484]
-Andrew
Build Log
eddie99
posted on 30/1/10 at 05:58 PM |
What they said!
Steve Hignett
posted on 30/1/10 at 06:03 PM |
I did that on the part in the last pic, with not much success!
atm92484
posted on 30/1/10 at 06:13 PM |
Hmm. In the wizard, did you select the "add cosmetic thread" option?
-Andrew
Build Log
Steve Hignett
posted on 30/1/10 at 06:15 PM |
Can't remember now, but think I did.
Will remove the item from the list and have another go!
Steve Hignett
posted on 30/1/10 at 06:41 PM |
I had already done that cosmetic thread jazzer...
Although didn't specify thread type (like 2b etc)?
m8kwr
posted on 30/1/10 at 06:46 PM |
I use SW 2009, in options, document properties, then detailing, make sure the "Shaded comestic threads" is selected, to see them.
Might be the same in other versions
HTH
Steve Hignett
posted on 30/1/10 at 07:07 PM |
I found that menu, but I can't find that option in the menu...
Steve Hignett
1
luke
posted on 30/1/10 at 07:09 PM |
thing to remember with solidworks is it doesnt make a thread, it just puts an image of the thread on the surface.
takes a while to get your head around that!
Steve Hignett
posted on 30/1/10 at 07:11 PM |
Thanks Luke, that's what I was asking in the original post and why I put that it was only the last photo that I'd tried to do that
on!!!
And as you know, it's not that I need to remember it, I need to learn it!!!
So I take it, I've done it correctly?
luke
posted on 30/1/10 at 07:21 PM |
7th picture down on your original post shows the thread as the inner line on the hole.
looks right to me
