Miks15
| posted on 15/3/10 at 04:16 PM |
solidworks help
Hi guys,
Ive done a model in solidworks for some uni coursework. And i have to hand an isometric drawing.
The problem is that when i press the isometric view button it gives me a view of the underside of the assembly, not of the front bit which i want.
Does anyone know how i can change it so that i have the isometric drawing of the right side of the model
Cheers guys
eddie99
| posted on 15/3/10 at 04:18 PM |
Re do it using the correct planes? I think you can make an assembly. Import the part and attach it onto the opposite plane and then the isometric view
will be correct. Wont work if this is already an assembly though.
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
Jimbob
| posted on 15/3/10 at 04:22 PM |
Cant you just drag it to the orientation you want, whack the spacebar and add a new named view? You can then pick that in your drawing as a view, bit
lazy tho!
[Edited on 15/3/10 by Jimbob]
brianthemagical
| posted on 15/3/10 at 04:42 PM |
Press space bar to bring up the view box thingy, find the front view you want, then click once on front then click on update STD views. Do that with
different views until it's constrained enough to give the iso view you're after.
[Edited on 15/3/10 by brianthemagical]
eddie99
| posted on 15/3/10 at 04:43 PM |
quote: Originally posted by brianthemagical
Using the above space bar method, find the front view you want, then click once on front then click on update STD views. Do that with differnt views
until it's constrained engouh to give the iso view you're after.
Then wont it mess up the views in every other part he ever does in Solidworks?
brianthemagical
| posted on 15/3/10 at 04:46 PM |
Not a clue tbh, i doubt it though. I'll have a look.
No, it doesn't.
eddie99
| posted on 15/3/10 at 04:50 PM |
Oh ok, Well problem solved then
brianthemagical
| posted on 15/3/10 at 04:53 PM |
TBH, I've only just figured it out. It's something i've wanted to be able to do for ages, but never really got round to trying it.
Miks15
| posted on 15/3/10 at 05:06 PM |
brian you really are magical
Never even knew about the spacebar views thing cheers for the quick replies guys
brianthemagical
| posted on 15/3/10 at 05:10 PM |
Glad i could help.
Which Uni are you at?
And, shameless plug, i've got a nice collection of Quadro FX gpu's if your after one at a good price.
brianthemagical
| posted on 15/3/10 at 05:18 PM |
Try holding shift and pressing the arrow keys, might have the same effect.
Miks15
| posted on 15/3/10 at 05:24 PM |
Im at birmingham uni, and no sorry not after any GPUs
