SALAD
| posted on 21/5/10 at 01:38 PM |
Formatting issue.
My laptop won't let me format the hard drive.
I'm trying to wipe XP off it and it keeps saying it can't format the hard drive because a window is open blah blah.....?
Any ideas? Am I being stupid or something??
cd.thomson
| posted on 21/5/10 at 01:49 PM |
youre not trying to format the active partition are you?
i.e. youre not trying to format your C drive from within windows which is running on your C drive?
Craig
big-vee-twin
| posted on 21/5/10 at 01:53 PM |
Cant do it in windows need to do it before windows starts
http://www.triangleltd.com
SALAD
Ha, who would try and do such a thing?!..........Yes Craig, yes I am.
Now what?
Mr G
| posted on 21/5/10 at 01:57 PM |
If you've got a windows install disc then you can boot up into that and select to remove the active partition and format the hard drive before
the windows install.
| posted on 21/5/10 at 01:59 PM |
Yup, wot he said, do it from the install disk....
SALAD
| posted on 21/5/10 at 02:00 PM |
I'm trying to remove XP and install 98. Had the 98 disk in and the computer set to boot from disk and it didn't (loaded up XP instead).
Then I tried finding the format option in BIOS before XP loaded and couldn't find it.....??
Davey D
| posted on 21/5/10 at 02:06 PM |
why on earth would you want to remove XP, and install 98? 98 is so outdated now, that you will struggle to find drivers for new devices. It is
also built on a crap flakey platform
SALAD
| posted on 21/5/10 at 02:08 PM |
It's for the Toughbook going to be used for megajolt.
All the drivers I can find to make the laptop work fully, wireless, touchscreen etc, only run to 98.
| posted on 21/5/10 at 02:10 PM |
I run mine on Windoze 2000 on my lappie...
Mr G
| posted on 21/5/10 at 02:11 PM |
Tried changing all boot devices to cd-rom? I.e first boot device, second boot device, third boot device
SALAD
It's not to get the megajolt working, it's to get the laptop fully functional.
Mr G
| posted on 21/5/10 at 02:13 PM |
What OS was originally on the laptop as standard?
SALAD
| posted on 21/5/10 at 02:14 PM |
I dont think it will let me Mr G. It lets you cycle through the boot options as in disk drive, hard drive etc then hard drive, disk drive etc etc but
not to input all disk drive or as an option...?
There is a sticker on the bottom for Windows 98.
It didn't have one when I got it.
[Edited on 21/5/10 by SALAD]
Mr G
| posted on 21/5/10 at 02:26 PM |
The thing with getting xp to run properly on old laptops is to make sure you note down all the hardware via the device mananger while its got its
original old os on it - this is the problem in your case if you say it came without one loaded
Without knowing the exact hardware specific drivers being used and finiding the proper xp equivalents you can have a right old time getting newer OS
running properly as xp defaults to generic drivers.
I've put xp on 2 very old laptops and was lucky enough to be able to see via 98 the specific drivers it needed (graphics/network etc etc) for
the install.
In all honesty going back to 98 would be a very last resort in my book. What are your issues with hardware on it with xp?
Edit : Should of said whats the model number? (It's Panasonic I presume)
[Edited on 21/5/10 by Mr G]
Mr G
| posted on 21/5/10 at 02:41 PM |
Pop in your model number HERE and search for the windows 2000
drivers if its quite old not xp and you might have some luck, especially with touchscreen drivers
SALAD
| posted on 21/5/10 at 02:42 PM |
As far as I can workout via the world wide web, I need to install the drivers to get all the aspects of the toughbook to work, i.e. touchscreen,
wireless etc.
The problem is all the drivers I can find only go up to 98.
If the equivilant XP drivers can be found, I'll go with them, but no luck as yet.
There is a list of drivers under system information on the laptop but I don't know enough about all this!
I've tried that site, but for XP. Will the Windows 2000 drivers work then?!
Mr G
| posted on 21/5/10 at 02:50 PM |
Yes they should be ok - Nothing to lose anyway giving them a try
Whats your model number?
SALAD
| posted on 21/5/10 at 02:51 PM |
CF27
Mk2 I think
Mr G
| posted on 21/5/10 at 02:59 PM |
Worth trying the close model numbers as well if the cf-27 one doesn't work i.e try the cf-28 drivers - there is a cisco wireless driver for it.
SALAD
| posted on 21/5/10 at 03:06 PM |
Thanks Mr G, I'll give it a try.....fingers crossed.
SteveWalker
It's certainly worth looking for 2000 or NT drivers, you should be able to use both of those under XP.
[Edited on 21/5/10 by SteveWalker]
Mr G
| posted on 21/5/10 at 03:14 PM |
Right I've got to go and cut the grass otherwise the gardening inspector (SWMBO) will not be happy.
Googled these results which confirmed using the cf-28 driver, although it seems to depend on the age of your cf-27 (old uses serial for the
screen,newer ps2)
Link1
Link2
Link 2 is a link thats mentioned in the Link1 thread.
Let me know how you get on, hopefully we can get you up and running and keep your OS in the 21st century
G
SALAD
| posted on 21/5/10 at 03:38 PM |
Thanks alot G. I will carry on....see what happens!
| posted on 21/5/10 at 03:40 PM |
Xp drivers may not be on the net because they may already be included in XP or can be found automatically by xp via Microsoft.
