Author: Subject: wood thickness
stevegough
posted on 22/6/10 at 08:35 AM Reply With Quote
wood thickness
About to get some mdf for the dash - which thickness do I need? 12mm / 18mm / 25mm / or....
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
stephen.holdcroft
posted on 22/6/10 at 08:44 AM Reply With Quote
wood thickness
Hi, What are you building a sherman tank, i used 6mm and this was almost to thick for my toggle switches.
stevegough
posted on 22/6/10 at 08:51 AM Reply With Quote
thanks for that, I thought if I made it thicker, I wouldn't have to stretch as far to the switches!!!
Luego Locost C20XE.
blakep82
posted on 22/6/10 at 09:31 AM Reply With Quote
my carbon dash is only about 3mm thick. 6mm will be more than fine.
won't MDF swell up if it gets damp though?
________________________
Bluemoon
posted on 22/6/10 at 09:43 AM Reply With Quote
If it's for IVA remember the radius bottom edge.. If you go thin you will need to add something, rather than carving it out of the dash, the radius is quite large (can't remember the number).
Dan
tomprescott
posted on 22/6/10 at 09:50 AM Reply With Quote
19mm (radius) springs to mind
A bird in the hand....
stevegough
posted on 22/6/10 at 10:50 AM Reply With Quote
That's great, thanks for your responses - 6mm it is - might be an idea to seal it with nitrate dope to prevent damp ingress. I am planning to IVA it, but 19mm is easily achieved in wood, I think.
Cheers, everyone!
Luego Locost C20XE.
posted on 22/6/10 at 11:24 AM Reply With Quote
Just remember that it's 19mm RADIUS, not diameter - in other words, 38mm diameter. It's quite a big radius to get on the bottom of a wooden dash (I used ply, with an extra layer stuck on the back at the bottom to give enough material to achieve the shape)
Slater
posted on 22/6/10 at 11:29 AM Reply With Quote
I used 6mm mdf with a wooden batons glued along the bottom edge, then radiused to 19mm (38mm dia) with a spoke shave/sandpaper, then sealed it all with mdf primer, gloss paint and then a coat of dry film lube for a pro satin finish.
[img][/img]
stevebubs
posted on 22/6/10 at 12:14 PM Reply With Quote
Would marine ply + varnish nor have been easier?
[img][/img]
Danozeman
posted on 22/6/10 at 02:04 PM Reply With Quote
Ply gives you wood grain to get rid off mdf is smooth.
Cant remember if mines 6mm or 9mm. Either ways its good and doesnt flex. i used foam around the bottom and they let me through sva.
Dan
posted on 22/6/10 at 02:21 PM Reply With Quote
I used 4mm ply Put a strengthening strip / bar at the bottom and job's a good'un.
RedAvon
posted on 22/6/10 at 03:20 PM Reply With Quote
Bit off topic but... Slater I'm pre IVA with the same steering wheel as you have in the picture. Do you know if it will pass IVA like that as i had to throw away the centre pad due to mouse damage! If not I'll have to buy another??
[Edited on 22/6/10 by RedAvon]
stevegough
posted on 22/6/10 at 03:36 PM Reply With Quote
That is a damn good point, David - one I might have missed!
Luego Locost C20XE.
