Author: Subject: Network hub / switch / router
posted on 5/7/10 at 09:08 AM Reply With Quote
If I'm networking my house will for media streaming will any old switch or hub work. Previously I've just used the router on the modem but that's only got 4 ports whereas I need 8. I've seen some cheap "switch / hubs" on Ebay but only the back is shown in the photo:
So if I want to connect 8 sockets and have a cable from the modem do I then need a 9 way (Ie a 10 way cos I don't think they do 9 ways) or will this have a socket on the side for the modem- reason I ask is the last wireless router I got was advertised as "4 way" but in fact had 4 LANS and a port for the cable from the moden.
I'm well confused
posted on 5/7/10 at 09:13 AM Reply With Quote
Actually I think I might need a router because I want everything on the network to be able to access the internet...
vinny1275
posted on 5/7/10 at 09:25 AM Reply With Quote
You'd struggle to get an 8-port router, you should be able to plug a switch straight into the router to make everything able to connect to the internet.
You want a switch rather than a hub, especially for streaming media, switches are more clever and know which addresses are on which ports - hubs make a lot of broadcast traffic.
As for whether that one's any good - no idea. I've been using a cheapy-cheap one at home for ages with no problems, don't really use that for streaming media tho. Something like a netgear would be fine if your budget will stretch that far - also, try and get gigabit if you can.
HTH
Vince
posted on 5/7/10 at 09:29 AM Reply With Quote
Aha! so I can just use all but one of the sockets on the router modem and then take the last one to a switch and carry on from there? I got confused when I read on another forum that a switch can't connect directly to a cable modem and has to be connected to a computer with two network cards (one for itself, one for the switch). Sounds very strange....
m8kwr
posted on 5/7/10 at 09:35 AM Reply With Quote
I have brought an xtreamer, for HD media streaming, links directly to my tv via a hdmi, the box itself has a wireless adapter, so no wires running to my router etc.
I have got an iphone app to control it as a remote.
You are able to insert a hard drive for extra storage. And its plays everything I have thrown at it. Links to you tube etc, or just play stuff from other network drives.
I would recommend one. I paid just over £100 for it.
LINK
posted on 5/7/10 at 09:39 AM Reply With Quote
LINK
Nice Only trouble is I've only installed a tv aerial and an ethernet to the television I probably should have run an HDMI from the TV up to the loft....
jossey
posted on 5/7/10 at 09:53 AM Reply With Quote
plug in a cheap 8 port switch and plug into your modem.
Try get a managed switch to secure what info goes out to the internet.
media centres can be a massive vulnerability when connected to the net.
http://www.cclonline.com/product-info.asp?product_id=22604&tid=gsearch
something like that will do the job but you need to ensure your router is secure for what ports are open etc.
dave j
cissp
posted on 5/7/10 at 09:56 AM Reply With Quote
dave j
cissp
Presumably that one's unmanaged cos it's cheap?
mad4x4
posted on 5/7/10 at 01:24 PM Reply With Quote
Get a class 3 Switch and set up Vlans and Routes. Good 24 port ones on Eblag 40 - 100 quid.
Scot's do it better in Kilts.
posted on 5/7/10 at 03:52 PM Reply With Quote
Ooooh class 3! Sounds posh. Wish I knew what it means. I think I need to learn a bit more about networks
jossey
posted on 5/7/10 at 05:09 PM Reply With Quote
Ye that ones unmanaged but will do if u manage your ports properly.
dave j
cissp
