robinj66
| posted on 7/9/10 at 09:13 PM |
Text too big
Help - when i turn on the computer the text is really large as are all the icons etc. Changing the text/icon size either in the window or control
panel does nothing - nor does the auto adjust on the lcd screen.
Any ideas as to what I do to rectify this?
MakeEverything
| posted on 7/9/10 at 09:15 PM |
Check your resolution.
Also, there is an option in Accessibility under control panel to make icons and text LARGE for the poor of sight!
Kindest Regards,
Richard.
austin man
| posted on 7/9/10 at 09:34 PM |
also look in the bottom right hand corner you should see a number with a percentage ideally this should be 100% any more and the text gets bigger
click to the right of this and reajust to suit
| posted on 7/9/10 at 10:12 PM |
..or hold down Ctrl and twiddle the wheel on your mouse
Liam
| posted on 7/9/10 at 10:43 PM |
Sounds like a problem with your video drivers has put you to default 640x480. Try reinstalling video drivers.
robinj66
| posted on 7/9/10 at 11:01 PM |
Thanks for all your help. It was the resolution thingy. Sorted for now
