RazMan
posted on 4/11/10 at 10:55 PM |
Which Idle Control Valve?
Continuing with my TB project I'm now looking for a small remote ICV - ie one with just hose connections so I can simply plumb it into a mini
plenum / vacuum box.
Is anything available either new or s/hand?
Another question - Do you think I should bother with an ICV at all as my MBE ECU has other ways to keep the tickover a little higher when cold
(advance timing mainly I think)
[Edited on 4-11-10 by RazMan]
Raz
austin man
posted on 4/11/10 at 11:08 PM |
I think the ford zetec has one (silvertop) sure it has one hose only
BenTyreman
posted on 4/11/10 at 11:11 PM |
What is your fuelling method? If it's Alpha-N (or whatever MBE call Alpha-N), then you might have problems adding air without altering the
throttle opening.
What about an actuator that operates on the throttle somehow?
RazMan
posted on 4/11/10 at 11:27 PM |
If controlling rpm with mainly a TPS and fuel are Alpha-N then I reckon that's what I've got . Its just that the MBE has a dedicated ICV
input so I was thinking of using it. I have been running without one for the last 4 years and it can be quite a long warm up during cold weather .....
and changing to ITBs is not going to be any better
Raz
BenTyreman
posted on 5/11/10 at 12:23 AM |
Not personal experience, just experience from what I have read where someone had connected an air bypass valve with TPS only fuelling. They noticed
significant AFR fluctuations (specifically leaning of mixture) due to unmetered air bypassing the throttle. If I remember correctly, they were used
the second fuel table on MS2 to add fuel in the MAP range affected by the idle valve. Of course, if you are in warm-up only mode, not closed-loop idle
control, then you might find that the small amount of extra air could be offset by richening the warm-up mixture slightly, if it is even a problem at
all.
I have a Vauxhall Ecotec idle valve, which operates by a solenoid pushing on the valve. I was considering removing the solenoid, which is bolted on,
and using it to directly push on the throttle in the place of the mechanical idle control. The amount of throttle required to raise the revs to over
2000rpm was only of the order of 1mm. However, through a mixture of increasing the advance from around 10 deg at 800rpm to 20 deg at 600rpm, and the
addition of around 6 deg of cold advance at 10 deg C, I never found the idle valve necessary for more than 10 or so seconds.
Incidentally, I found that the throttle bodies I have are fitted with a choke in the vacuum take off points on each barrel. The choke is so small that
it doesn't flow enough air to significantly affect the revs.
Dusty
posted on 5/11/10 at 02:22 AM |
I run Omex 600 ECU + Jenveys on the ST170 engine. It has the option of ICV or ignition advance/retard for idle speed control. I use ignition and
it's rock steady, freezing or hot. I wouldn't bother for a second thinking about ICV.
RazMan
posted on 5/11/10 at 09:22 AM |
Thanks for the useful info guys - I think I will have a go at using the ignition timing and keep it simple - mind you, mapping with the MBE is
certainly not a simple process
Raz
matt_gsxr
posted on 5/11/10 at 10:02 AM |
I think there is some information in the megasquirt manuals on ICV's and different versions. I can't find it with a quick google.
Sorry.
Fair amount of information here on what cars have what in the way of ICV,
http://www.diyautotune.com/tech_articles/megasquirt_install_writeups.htm
Matt
